2026 Mercedes-AMG Petronas F1 Team
gearboxtrouble
gearboxtrouble
Re: 2026 Mercedes-AMG Petronas F1 Team
26 Jul 2026, 18:04
Toto Wolff on blue flags in Hungary: "The problem is that some engineers on the pit wall are absolute Teletubbies and would rather stare up at the sky than tell their drivers that there’s a train of leading drivers coming from behind and that they’re fighting for positions."
Quote of the weekend. :lol:
I wonder if he confused Muppets and Teletubbies lol.
zibby43
zibby43
gearboxtrouble wrote:
26 Jul 2026, 20:16
26 Jul 2026, 18:04
I think he may have nailed it with Teletubbies because in the interview, he said something to the effect of, and I'm paraphrasing, "mute like Teletubbies." I know what a Teletubby is but I have never seen it so if they're not mute, then maybe that wasn't the proper comparison lol.
MB_Racer
MB_Racer
zibby43 wrote:
26 Jul 2026, 20:15
Ferrari really threw us a lifeline this weekend. Kimi extended his lead in the WDC and basically kept the WCC frozen in place.
Damage limitation heading into the summer rather than limping into the summer. Team should be very motivated to come back strong after the break.
Exactly! Well summed up.
Great job by Kimi, and only one point lost to Ferrari in the Constructors’ Championship.
That’s excellent damage limitation considering the horrible grid position!
Waz
Waz
Kimi is driving really maturely in the last 2 races. He's lost the teen angst from earlier in the year when he wasn't in the lead.
clownfish
26 Jul 2026, 17:12
edited: Antonelli explained what happened to Russell. The battery was topped up too much which meant the turbo could no longer build boost (it needs to be able to load the engine against the MGUK in order to build boost). Without boost, the car had no power and went to anti-stall when the dropped the clutch.
Here's what George said
"I was on the throttle holding the revs, and then all of a sudden, about four seconds before the lights went out, the engine just started revving all over the place," Russell said. "I was reacting with my throttle, and it was doing nothing. So, the engine wasn't reacting to the throttle."
https://www.espn.co.uk/f1/story/_/id/49 ... ungaroring
Plausible it could have been caused by the ers failing to provide the expected load.
Lasssept
137
clownfish wrote:
27 Jul 2026, 14:16
26 Jul 2026, 17:12
I agree I think there is a connection between the ERS no longer charging, and the revs rising. Motorsport.com posted some telemetry. Antonelli seemed to know right away what it was, so it's likely that they have experienced this before on the Merc PU.
Beware of T-Rex
Farnborough
Farnborough
152
27 Jul 2026, 15:08
clownfish wrote:
27 Jul 2026, 14:16
26 Jul 2026, 17:12
https://i.redd.it/rqz9wpls9rfh1.png
If the ERS has to drop loading, because its full (Antonelli word was "stack" full, I thought) then ICE will show that to GR in feel. He responded by taking foot off throttle, boost from Turbo was, correctly, quenched. Lights out and GR releases clutch against expected ICE under boost load, to find it's not available. Traction then triggers anti stall, by pulling clutch to make available "go again" then you could see how long the turbo lag took to reduce as everyone keeps sweeping by GR.
Looks like GR got the final approach wrong, that to overfill the battery prior to start routine demand that's used to build boost.
Don't feel there's mystery "control" but circumstances tripped over by driver.
Farnborough wrote:
27 Jul 2026, 15:26
27 Jul 2026, 15:08
clownfish wrote:
27 Jul 2026, 14:16
On the surface yes it would seem that the battery pack (aka Energy Store/ES) became full (for some reason). Whether that's on the driver or not is hard to say with these PUs. If he began the pre-start procedure too early, then yes that would be his fault, but if there was software issue in the formation lap then it might not be.
Beware of T-Rex
Farnborough
Farnborough
152
I can see that, and discussion about procedure and effectiveness of that against resources during pre start routine valid.
But don't see conspiracy in what happened with throttle as load come off in final seconds before launch. Looks like the result was entirely logical once the energy store was maxed out, at which point it could no longer reasonably be used as brake to run turbo boost accumulation against.
