Tungsten crank counterweight
Shrek
Shrek
since the counterweights can only be so light, why not make them from tungsten/lead so it will not touch the oil as much or not at all?
Spencer
tok-tokkie
tok-tokkie
38
Re: Tungsten crank counterweight
Surely they are dry sump engines so oil 'windage' is not an issue.
bhall
bhall
244
And, I believe, tungsten is banned for use as a material in the construction of F1 cars.
EDIT: Nevermind. I was thinking of a different metal.
marcush.
marcush.
159
Shrek wrote:since the counterweights can only be so light, why not make them from tungsten/lead so it will not touch the oil as much or not at all?
is this really a new idea to you? :shock:
Shrek
Shrek
yes because i've only been a fan of Formula 1 for 2 years and trying to learn about the past
Spencer
marcush.
marcush.
159
Tungsten fitting to counterweights is not unusual at all outside F1
Shrek
Shrek
marcush. wrote:Tungsten fitting to counterweights is not unusual at all outside F1
i mean as the counterweight not drilling a hole in the counterweight and puting a slug in
Spencer
tc9604
tc9604
How exactly are you attaching this tungsten?
flynfrog
heat shrink
or press fit and swedge
green loctite
take your pick
safeaschuck
Yep, i've seen some very high spec cranks with bolt on counterweights.
riff_raff
riff_raff
132
F1 cranks cannot use tungsten counterweights according to the regulations. I believe the rules state that the crankshaft must be constructed entirely of ferrous materials.
A: Start with a large one!"
Mikey_s
Mikey_s
riff_raff wrote:F1 cranks cannot use tungsten counterweights according to the regulations. I believe the rules state that the crankshaft must be constructed entirely of ferrous materials.
it's here...
5.14.4 Crankshafts must be manufactured from an iron based alloy.
They used tungsten based counterweights in the past, but it's banned now...
Mike
Edis
Edis
59
F1 engines use crankshafts with tungsten alloy counterweights that are bolted onto the crankshaft. The tungsten alloy they use is an ammunitions grade alloy that also meets the 19000 kg/m^3 limit stated by the regulations.
Ammunitions grade tungsten alloy, normally found in armor piercing ammunition, offers a higher strength than normal tungsten high density alloys, required when using it in the form of screwed on weights rather than pressed in slugs. You don't want one of these to get loose at high speed, it would go straight through the car and in best case cause a hole in the race track.
Tungsten counterweights can be seen at this picture: http://www.gurneyflap.com/Resources/P7110091.jpg
From the regulations
No welding is permitted between the front and rear main bearing journals.
No material with a density exceeding 19,000kg/m3 may be assembled to the crankshaft.
