Most fuel efficent engine for 2010?
CHT
CHT
-6
1) Will engine fuel efficiency determine 2010 championship?
2) With the restriction on engine modification, will new comer like Cosworth have an advantage over the rest or the grid?
jac
jac
Re: Most fuel efficent engine for 2010?
hi,
CHT wrote:1) Will engine fuel efficiency determine 2010 championship?
Well, yes & no. The "best" engine will be one which consumes the least amount of fuel whilst producing the most amount of power relative to the other engine brands. To my mind, Mercedes & Renault certainly have this advantage to say the least. Fuel efficiency will certainly play a role in the championship - but the extent of this remains to be seen. Also, there are way too many other factors that have to be taken into account for (ex. how good the car is mechanically - chassis etc.)
CHT wrote:2) With the restriction on engine modification, will new comer like Cosworth have an advantage over the rest or the grid?
No. I don't think Cosworth will have ANY real advantage over other engines such as the Merc & Renault, including the likes of Ferrari. There are rumors floating about that the Cosworth lump might turn out to be the more powerful engine on the grid. Even if that turns out to be the case (unlikely), we still don't know how fuel efficient they are... (in the event they're not, they'll have to carry more fuel to finish the race, which might compromise their pace in the early stages of the race on full tanks - despite having a more "powerful" engine)
The truth will only unfold after qualifying in Bahrain I'm afraid, so I guess we'll have to wait.
I've searched hard for some info/specs re the Cosworth, but couldn't find anything solid...
Anyone?
djones
djones
At a guess would we say the Mercedes is the best engine overall?
jac
jac
djones wrote:At a guess would we say the Mercedes is the best engine overall?
In terms of power produced relative to fuel consumption, then yes, the Merc is best overall.
I can't wait for the full "race" fuel loads to be released after quali Bahrain. That should give us a very clear indication as to which engines are better at fuel management.
I'm expecting either Merc GP/Mclaren or Red Bull at the front in Bahrain...
WhiteBlue
92
Agree Cosworth are unlikely to be the top dog engine wise in 2010. That will be between Merc and Renault I think. Both will be close running with Cosworth an Ferrari making up the numbers in terms of engine performance.
The whole engine thing will be only 30% of the game. The rest will be chassis and mostly aero IMHO.
JohnsonsEvilTwin
In 2009 The Mercedes-Benz V8 was the most powerful engine in F1, I think we can all agree. Similarly, the Renault V8 was also the most frugal of all the engine's last year.
With engine freeze rules, one would expect things to be the same. However there is still some scope for development. If the manufacturer can prove an adjustement is made to further reliabilty, then it will be allowed. Also the exhaust is not part of the freeze, and big gains can be made through exhaust development.
Yesterday Domenicalli spoke of "big gains" made in this area. Wether that is PR speak I cannot say. But Shell have apprently been working closely with Ferrari on the fuel consumption side of things too.
Overall Mercedes are still in the driving seat fiollowed very closely by Renault and then Ferrari.
Cosworth will be dark horses as I feel Max gave them many concessions, allowing them to update their V8 with 2009 "know how" and not the 2007 "know how" everyone else had. So I wouldnt be in the least bit surprised if Cosworth sprang a surprise and was the best engine to have.
If they(Cosworth) are the best, it would be another telling max mosley act of favouring one team over the other. My guess is all the manufacturers are watching Cosworth very closley to see how things pan out over the february tests.
Will the manufacturers demand "equalisation" if Cosworth are found to be the best?
One thing is for sure, 2010 is shaping up to be the best F1 season in living memory! :D
More could have been done.
David Purley
raceman
JohnsonsEvilTwin wrote:One thing is for sure, 2010 is shaping up to be the best F1 season in living memory! :D
indeed :P
tarzoon
indeed :P
we just need the "balls out qualifying" (quoting WB)
ESPImperium
ESPImperium
64
As the rule of thumb, going on the 2009 engines and 2009 race pace, the table for fuel tank size to HB looks like this:
Mercedes FO108W = 155KG tank running optimal 760HP
Ferarri 056 = 165kg takn running at optimal 755HP
Renault RS27 = 140KG tank running at optimal 745HP
Toyota RVX-09 = 135KG tank running at optimal 738HP
BMW P86/9 = 158KG tank running at optimal 752HP
Time comparisons from the Mercedes block to the Toyota block from 09 is arround 0.3 a second a lap, but the thing was the cars the Toyota power was in, those cars were better designed from a aero angle than the Mercedes and Ferarri cars if you exclude the Brawn BGP001.
Rumor has it that the CA2010 can pump out arround 770HP, but if that was taken as its optimal power, you would look at somewhere near 177KG of fuel, just to make it over the line and no more, more like 180KG is ideally needed as you will see the cars doing less reconaciance laps this year before a race, more like Pits to Grid, no cutting thrugh the pits to loose some fuel weight.
Fuel milage will be a big part of strategy, but the Ferarri and Mercedes engines are more or less at the area the Renault engine was at last year, but are posibly just a fraction off the 09 mark at present, but they are catching up fast. One way they have done this is to actually cut some horespower away for the start of the season, and then over the season regain what they lost whilst keeping or bettering milage. Id say they could cut as much as 10HP away then regain that and up to double that over the season.
jac
jac
tarzoon wrote:One way they have done this is to actually cut some horespower away for the start of the season, and then over the season regain what they lost whilst keeping or bettering milage
De-tuning....mmmm. That's exactly what I was thinking as well. Makes sense though.
ESPImperium wrote:Mercedes FO108W = 155KG tank running optimal 760HP
If indeed these figures are anywhere near correct - that would still put the Merc & Renault lump waaayyy ahead of the competition. The Renault's 15hp or so deficit should not be any problem at all - as they'll have the added benefit of having more ballast to play with.
In the end, I think horsepower will be less of a factor this season. But that's just my opinion - I may be wrong.
ISLAMATRON
jac wrote:If indeed these figures are anywhere near correct - that would still put the Merc & Renault lump waaayyy ahead of the competition. The Renault's 15hp or so deficit should not be any problem at all - as they'll have the added benefit of having more ballast to play with.
What ballast are you talking about? All cars must weigh 620KG with driver sans fuel. HP has nothing to do with ballast and neither does how much fuel you use... but yes if the Renault is more fuel efficient will have to lug around less fuel every lap than its competitors.
With refueling banned, Peak HP is less important, fuel consumption is more important, drivability is more important, thermal effiency is more important, as are cooling requirements. When you run leaner the engine is typically hotter, thus requiring more cooling capacity and that usually means larger sidepod openings and thus more drag and then higher fuel consumption... it is a vicious circle that must be balanced.
jac
jac
ISLAMATRON wrote:With refueling banned, Peak HP is less important, fuel consumption is more important, drivability is more important, thermal effiency is more important, as are cooling requirements. When you run leaner the engine is typically hotter, thus requiring more cooling capacity and that usually means larger sidepod openings and thus more drag and then higher fuel consumption... it is a vicious circle that must be balanced.
I agree. Hence the reason I think Merc got this "balance" spot on last year. I'm expecting it to play into the hands on the Merc-powered cars, especially Mclaren.
ISLAMATRON
You still didnt clarify your "more ballast to play with" statement...
jac
jac
my misunderstanding. sorry.
ISLAMATRON
ESPImperium wrote:As the rule of thumb, going on the 2009 engines and 2009 race pace, the table for fuel tank size to HB looks like this:
They can do as many recon laps as they want, refueling is allowed even while sitting on the grid AFAIK. Recon laps will be the new sunday morning warmup. It might get to the point where teams might be limited on recon laps by the FIA... but that is already somewhat limited by when the track is opened for recon laps.
How/where are you getting these fuel weights and HP numbers?
