We can easily see the 'roof' of the diffuser just under the brake duct.Longley wrote:![]()
I'm not talking about under the airbox, that's just like they had last season and probably isn't an opening, just some clever aero.n smikle wrote:Dead zone located, I was suspecting all this time the inside of the bodywork could be used aerodynamically, however i did not want to spoil it for everybody. After the whole Goony thing from the start of the thread we all avoided the whole deadzone thing. Being a Mclaren fan too, i don't want other teams using Mclaren's innovationsDiesel wrote:Look inside the airbox, two channels.
http://www.f1fanatic.co.uk/wp-content/u ... 4_25_2.jpg![]()
That opening under the air intake, may well be linked to the shark fin round back, Similar to the 2008 Ferrari nose.
The dead zone is hiding behind the unicornastracrazy wrote:how would air going into the airbox create a deadzone?
I see 3 openings. The two you mention in the airbox scoop, but there is also an opening under the scoop, next to the "Boss" logo.Diesel wrote:Inside the air box you can see something at the top sectioning it off. I suspect the bottom half feeds the engine and the top half is for cooling.
The V-nose implies a curved bottom of the nose. Since they are using a front splitter, a curved surface would probably allow air to spill upwards, preventing flow stagnation on the upper side of the splitter and reducing its efficience.ISLAMATRON wrote:I too am shocked they didnt go with the V-nose design, what may be any disadvantages to it?
It's not an opening as such, Brawn had it last year, McLaren had the same configuration last year as well. There is no hole through to the engine, how could there be? What's behind that area under the airbox? erm... the Airbox!!!richard_leeds wrote:I see 3 openings. The two you mention in the airbox scoop, but there is also an opening under the scoop, next to the "Boss" logo.Diesel wrote:Inside the air box you can see something at the top sectioning it off. I suspect the bottom half feeds the engine and the top half is for cooling.
Good point, I did not think about its interaction with the front splitter.dumrick wrote:The V-nose implies a curved bottom of the nose. Since they are using a front splitter, a curved surface would probably allow air to spill upwards, preventing flow stagnation on the upper side of the splitter and reducing its efficience.ISLAMATRON wrote:I too am shocked they didnt go with the V-nose design, what may be any disadvantages to it?
I was thinking this as well, that the lower "deck" would be a very shallow plane to make the second deck legal which would be a full height full width channel. Not sure if this is possible though.Mysticf1 wrote:Hey F1 techers, first time poster, VERY long time reader.
This may be way off the mark, but what is the possibility that there wont be multi deck diffusers at all....but a maximum use of the what was the upper deck fed by slots? From the limited images we have of the Mclaren it seems the diffuser is the same height the entire width...i do concede that the floor of the launch car was most likely built solely for the launch.
Mick
That's what I was thinking (but didn't say). 2 inlets for ducts, one for general air flow though the engine compartment, then out the open coke bottle at the back just in front of the bridge wingDiesel wrote:It's not an opening as such, Brawn had it last year, McLaren had the same configuration last year as well. There is no hole through to the engine, how could there be? What's behind that area under the airbox? erm... the Airbox!!!richard_leeds wrote:I see 3 openings. The two you mention in the airbox scoop, but there is also an opening under the scoop, next to the "Boss" logo.Diesel wrote:Inside the air box you can see something at the top sectioning it off. I suspect the bottom half feeds the engine and the top half is for cooling.
There is a separate duct from the airbox - underneath the one that leads to the engine which through the shark fin to components at the rear of the car.Diesel wrote:It's not an opening as such, Brawn had it last year, McLaren had the same configuration last year as well. There is no hole through to the engine, how could there be? What's behind that area under the airbox? erm... the Airbox!!!richard_leeds wrote:I see 3 openings. The two you mention in the airbox scoop, but there is also an opening under the scoop, next to the "Boss" logo.Diesel wrote:Inside the air box you can see something at the top sectioning it off. I suspect the bottom half feeds the engine and the top half is for cooling.
