ringo wrote:I agree the performance can't be viewed independent of the cars however the thermal efficiency of these engines can be.
The logical way to get an indicator of the efficiency is if we had 2 different engines in 1 type of car.
The problem is we only have examples of 1 type of engine used in 2 different cars in F1, but then it doesn't say much because we want to compare different engines not the cars...
How useful would it to compare fuel consumption figures for 2007 - 2009? The alleged engine freeze should mean that variations in consumption are down to the changes made to the car it was used in over the 3 seasons.
Is it true that downforce levels have increased year on year (for all the cars, even those that didn't have a DDD at the beginning of 2009) despite the efforts of the TWG? If downforce was correlated to drag then we would see a similar increase in fuel consumption in all 3 seasons.
The thing is that I think that the aero development in F1 has focussed on increasing downforce without significantly increasing drag - or the case of the DDD, probably reducing drag. And unless we can infer drag to lift ratio (let's call it aero efficiency) from avg laptimes then we can't know what part of the fuel consumption equation is contributed by the engine efficiency and what part the aero efficiency.
And let's not forget mechanical efficiency (rolling resistance)!
May be we can quantify it as follows
fuel_consumption = season_avg_laptime^-1 * (engine_efficiency + aero_efficiency + mechanical_efficiency)^-1
With a few constants in there to reflect relative contributions of each term. I think we need to normalise the RHS by the average laptime because the faster the car the higher its fuel consumption all other things being equal. Oh but then we introduce the weight of the driver's right foot in to the equation.
