MS27 wrote:Murdock wrote:Hello guys, I was wondering if anyone knows what type of cam profile F1 uses (in general) for such high rpms. The only information i could find was they had "surprisingly little overlap considering the duration necessary to assure breathing at 17,000 rpm". I tried using a desktop dyno just to get in the ballpark but it max's out around 11K I believe.
Any information is appreciated.
Hello guys!
First I want to introduce myself a little bit. I´m crazy about cars especially engines since I was a kid...Now I study mechanical engineering and i´m writing a dissertation about F1 engines at a university in Germany (sorry, if my english is bad
But, as you can imagine, I haven ´t found precise information about valve timing, especially duration of a Formula one engine. The only information I have is that it must be over 360 degree...
Do you have some information so far?
Thank you very much!
Regards from Germany,
Martin
Valve duration is rarely higher than 330 degrees (660 degrees when combining exhaust + intake duration). To get 330 degrees duration you can for instance open the inlet valve at 75 degrees before TDC and then close it 75 degrees after BDC. The duration then becomes 75+180+75 degrees = 330 degrees.
Often the duration is given at a certain lift, for instance 250 deg @ 1 mm lift. In other words, it takes 250 crankshaft degrees to get from a lift of 1 mm to peak lift and back to 1 mm lift.
SAE 2002-01-3359 'Demands on Formula One Engines and Subsequent Development Strategies' by Illien and Alten used to following assumptions for engine simulation:
B/S-Ratio : 1.95
Conrod Length : 115mm
Compression Ratio : 13.2:1
Inlet Valve Size*) : 1/3 * Bore Area
Timing @ 1mm Lift : 10º BTDC / 240º ATDC
Max. Effective Flow Area : 1525 mm2
Exhaust Valves Size*) : 1/5 * Bore Area
Timing @ 1mm Lift : 245º BTDC / 8º ATDC
Max. Effective Flow Area : 1410 mm2
*) Related to Valve Inner Seat Diameter
