Tbox, most teams were better coupling them last year already - you could see it on wet tests quite clearly. Toyota was great from day 1.
Pup, it's not quite the same discussion. But if you've got objections to the way it's brought about, fair enough. FWIW I've not been reading since page 40 (nor am I going to backtrack - don't have the time).
What you're describing for viz over a two-element wing in high downforce configuration is quite normal. There's something more interesting going on at mid span but nothing terribly definitive. If it is intended to occasionally stall the wing, the sear forces on the flow viz mixture are going to be greater when flow it attached, and over a few laps' worth of drying off you'd more likely see the effect of the wing working normally.
