Mclaren Mercedes MP4-25
SLC
SLC
Re: Vodafone Mclaren Mercedes MP4/25
Pierce89 wrote:http://scarbsf1.wordpress.com/2010/02/1 ... /#comments
Macca had a blown flap at MONACO 09. It's for increased downforce not reduced drag. @SLC: you're wrong. drop it.
I already posted and said that the 2010 rear wing effect is the opposite of the 2009 wing effect.
The blown flap last year was to prevent stalling.
This year it is to induce stalling.
Scarbs is wrong, unfortunately. He is quite a lot of the time.
mstar
mstar
well scarbs is actually at the tests and is going to barcelona test, so its more info then we have :roll:
SLC
SLC
Pierce89 wrote: Dude Please!!! Increasing energy under the wing(with a stream of air) to decrease seperation would give increase in effiency. More benefit over entire lap and much more plausible because it doesn't require near as much air as eliminating the low pressure zone would.
Unfortunately it seems it is too difficult to argue with people who are unwilling to listen.
You are somewhat correct. Increasing the energy along the suction surface of a wing will help its performance. This is what McLaren and BMW were doing last year. This year McLaren are trying to stall the wing. It's the opposite effect.
richard_leeds wrote: Sources?
My phd in ground vehicle aerodynamics and my copious years designing F1 cars.
mstar
mstar
SLC does it give any laptime advantage, as i am thinking this concept is not used by many cars at all. Sorry i am not a techical person like you guys, so dnt pretend to either :)
Raptor22
Raptor22
26
ah the std answer, quote the highest quaification + closest association with the sport.
until you show me pictures of a car running around a track with a stalled rear wing I won;t beleive it.
Besides, if you're an F1 designer, where do you find the time to post on internet forums?
raceman
Raptor22 wrote:Besides, if you're an F1 designer, where do you find the time to post on internet forums?
quite rite
:-s
Richard
Richard
I was referring to the "been working on it for 3 years" bit.
SLC
SLC
richard_leeds wrote: I was referring to the "been working on it for 3 years" bit.
Ah. Well there's the convenient bit - I can't say where I know this!
SLC
SLC
Raptor22 wrote:ah the std answer, quote the highest quaification + closest association with the sport.
Whatever.
Spencifer_Murphy
The only problem I have with the stalling idea is this:
And please note SLC I'm not flaming you or attacking you, I'm simply stating wat I know and would like to be enlightened if possible.
I've got a BEng(hons) in Aerospace Engineering, so I do know about aerodynamics, tho I DO NOT have the knowledge that SLC has.
But it is my understanding that a blown flap will delay the onset of stall. It's as simple as that. How can a blown flap enduce stall (unless the direction of the blow is opposite to the direction of flow? lol)
Furthermore, fundamentally, if I wing is stalling it increases drag, simple as.
Obviously there could be far more complex things going on here than I understand, hence my asking. (For example imagine my suprise when I first learn of compressible flow, when a divergent nozzle actually INCREASES flow velocity lol)
But to my knowledge those two point I make, make the whole concept of deliberatly stalling a wing seem not only pointless to an F1 team but also counter-productive.
Silence is golden when you don't know a good answer.
autogyro
autogyro
53
Surely in the very simplest terms.
Stalling any lift surface increases drag but channeling a reasonable volume of air to a different area can be used to reduce drag?
Interesting work by McLaren anyway.
zgred
Poleman
The only differences i could spot in this pic was those :?: ducts :?: behind the front wing and that today are running only one side vent. :roll: :roll:
horse
Ladies and Gentlemen,
I thought, maybe that splitting off the stalled wing argument might be a good idea, as it's so theoretical and possibly not related to this car.
So I made a new thread here:
viewtopic.php?f=6&t=8028
Please come and share your ideas (possibly over and over again) ;)
dont know if its already said, but i saw those slits from another view(on the sidepods) And i came to an conclusion, it keeps the flow attached to the sidepod(dunno if such an object can stall though).
It was some sort of wing in front of the wing wich allowed it to be run at larger angles to stall, i think that is what it does on the sidepod.
