The only other car with hydraulic suspension system prior to Lotus (not active) is the Brabham BT49C.
But his was for lowering the car to bypass the regulation of a minimum ride height.
No, I don't mean that car. As you correctly noted it was not an active or semi-active system.matt21 wrote:But his was for lowering the car to bypass the regulation of a minimum ride height.
Yes, but there was another one. If noone would name it by the end of the day, it would be your turn.matt21 wrote:The Lotus 92 ran a hydraulic system 1983 at the Brazilian and Long Beach Grand Prixs.
A hint: note that Williamses used semi-active suspension, Lotus 92 was active.matt21 wrote:I think it is earlier?
It is from Peter Wright's book "Formula 1 technology"matt21 wrote:Can you provide me the source for this?
