mx_tifosi wrote:The current ECU's have more flexibility than you currently imagine, as they have many maps to go through if needed, from the leaner to richer mixtures of the spectrum.
There should always be enough fuel to finish a race despite no SC even in the very last third stint, in case there is one in the last few laps or whatnot, IMO. And if there isn't one just turn up to a richer mixture just for the added hp.
Yes, but fuel can only be effectively turned into power up to a certain point. After that point, the extra fuel could not be burned quickly enough. If there is a long safety care period, a car could have a truly massive and
completely worthless surplus of fuel. Worse than worthless, the fuel surplus would drastically hurt lap times.
They start the race with what? 160 KG of fuel? An especially long safety car period could result in a 10 or 20 KG surplus of fuel that would need to be removed in a mere handful of laps. One certainly must wonder if so many liters of fuel could be burned in such a short period of time. I tend to think they could not.
In F1 terms, 10KG is a
massive amount of needless mass, especially when one considers that the teams have been known to spend $100K to lose 100 grams.
My point is that such a situation is bound to happen a few times this season. I cannot imagine that the teams haven't considered this eventually and methods to quickly dispense of large amounts of needless fuel.
It was pointed out above that it would make some rather bad press if teams were to admit to dumping huge amounts unburnt fuel. I agree, and perhaps that's why this possibility is not being openly talked about by the teams. Just because it would make bad press doesn't mean there aren't systems to quietly accomplish the deed.
