Carbon Industries Contact
lkelm15
lkelm15
I work as a member of a landspeed racing team currently in the development of a new vehicle which is being designed to break the current wheel-driven record. The brakes we use now would not hold up should we try to stop the car from speed. As F1 is the most technologically advanced motorsport, we have been looking to deal with the same companies they do in order to find a solution. Would anyone here be able to furnish the contact information for Carbon Industries?
Jersey Tom
Jersey Tom
167
Re: Carbon Industries Contact
And you wouldn't use parachutes?
mx_tifoso
mx_tifoso
I was going to say the same thing Tom, but I figured it would be an obvious braking/safety component.
At least I certainly hope so in this specific case. :? It would be worrying if not.
At some point brakes will be required even with parachutes. The thing about landspeed records is to reduce the time between runs to no more than 1 hour. If you can stop the car a few hundred metres shorter then you have more time for the ground crew to turn the vehicle around. The crew need to travel from their holding point to the stopping point of the vehicle. This takes precious minutes.
mx_tifoso
mx_tifoso
Yes, but carbon over steel?
When do these type of cars depend most on the disc brakes? Towards the end after the parachute has taken down most of the speed?
mx_tifosi wrote:Yes, but carbon over steel?
True, but hitting the brakes at 250mph might be useful over hitting them at 150mph. Also, landspeed vhicles are quite heavy. 7 tonnes in the case of Bloodhound. That's also going to put extra energy through the brakes.
lkelm15
lkelm15
We do use parachutes to slow from 300-400 mph down to around 150-200 mph but after that point they do very little. The primary reason for brakes is testing; we do most of it at less than 150 mph and first buying larger chutes then repacking them after each test run is alot of time unnecessarily wasted.
