jon-mullen wrote:I'm glad somebody brought up the TV telemetry because I've been wondering for a while:
The brake indicator seems to be on or off, not graduated in anyway. Is that down to driving style or is that the indicator itself?
The style of the indicator. Although in Racing you're often braking heavily, so you'll be near the maximum grip anyway (essentially emergency braking every time). Only trail-braking and if you're not at maximum attack will you get a difference in the brake applciation.
So I think they thought that a graduated bar would be pretty pointless as it'd be at 100% most of the time anyway, where-as the throttle application out of corners and through corners can be interesting, i.e. who's got more throttle where.
Not sure if in MotoGP they have a graduated brake indicator either. They use trail-braking alot.
"It could be done manually. It would take quite a while, but it could be done. There is however a much more efficient and accurate way of getting the data. Men with lasers." Wing Commander Andy Green
