Upright Photos
MrT
MrT
Upright Photos
Hi im still looking for some photos of f1 uprights which have the pushrod mounted on the upright itself . Ive looked on gurney flap and on the net and can't find any satisfactory photos. If you guys have any could you post them here?
Thanks
MrT
West
West
Does scarbsf1.com have it?
Bring back wider rear wings, V10s, and tobacco advertisements
manchild
manchild
I don't think that it is possible to find photo of pushrod and upright connection unless someone has previously removed brake ducts and than reassembled the suspension.
rear suspension Renault 2002
sketch front suspension
Lola champcar upright
http://www.lolachampcar.com/images/Susp ... pright.jpg
OT - Also found this while I was searching - gearbox and diff
Guest
Guest
Thanks guys.
Guest
Guest
ive got heaps but i cant seem to login
Guest
Guest
I have some in my F1 Gallery from 2004
http://supercarfreak.net/gallery/RacingManiac
zac510
zac510
22
Anonymous wrote:I have some in my F1 Gallery from 2004
Great pics! I'm disappointed it has taken me this long to find them :(
manchild
manchild
scarbs
scarbs
393
Here you can see the pushrod is on the upright.
http://www.supercarfreak.net/gallery/album728/PICT0038
Some Keel less cars have the mounting nearer the hub centre line.
[img]http:600:450]http://www.scarbsf1.com/toyo_upright.JPG[/img]
RacingManiac
RacingManiac
having the pushrod mounted to the upright, does it mean you have a changing rate as you steer?
Scuderia_Russ
Not if the centreline of the spherical bearing is in line with the castor I wouldn't have thought.
TudorMiron
TudorMiron
Re: Upright Photos
Having the pushrod mounted on the upright (front) allows to transfer load to inside wheel when steering. Amount of load transfer could be changed by moving connecting point longitudinally (relative to wheel axis). This is in some way similar to load transfer when steering due to castor angle.
Hope this helps.
Cheers
Ted
