![Image](http://img580.imageshack.us/img580/1428/1040414.jpg)
this is the first mockup of a four cylinder unit. the combustion chamber shape was far from ideal but later we packaged things better and got the ports to the two valves much smaller and had a much better shaped combustion chamber.
Then you must be comparing them in a very unscientific way. With multiple variables you cannot attribute what components cause gains and what cause losses. Basically you know what the differences are but not why they are different.autogyro wrote:I cannot agree Chris when you say that comparisons cannot be made between engines of very different design concepts.
The one I saw was newer than that, it was early 2000's, but if you don't mind scanning it i'd love to have a read.rotaryvalveman wrote: is the SAE paper you refer to headed titled, "Rotary Valves for Small Four-Cycle IC Engines", paper number 891793. If so it is sitting on my desk in front of me and was written for the 1989 small engine technology conference in Milwaukee, Wisconsin. If you like I could scan it and send it to you for your review.
What? The BMEP is the only simple way to compare an engines capacity to do work independent of displacements and configurations.autogyro wrote:I do not think comparing the BMEP of a highly blown F1 engine from the 80's is a fair comparison of anything other than the capability of an engine design to stay together at such high forced outputs.
However this does establish a bench mark for many aspects of reliability when comparing sleeve and rotary valves.
Certainly many of the advantages of sleeve and rotary valves are negated at high boost levels.
Cheers.rotaryvalveman wrote:Chris
I will get the SAE paper scanned this week and e-mail it or send it to you in what ever form you wish.
