Red Bull RB6
BreezyRacer
BreezyRacer
Re: Red Bull RB6
Boy, is there ever a race where Red Bull don't have some new wings to test? I wonder which one they settled on?
volarchico
volarchico
Re: Red Bull RB6
Those wings are proper art work...amazing.
strad
117
Re: Red Bull RB6
I doubt the exhausts are coated with anything, that would add weight..More interesting is the semi twin outlet exhaust.
Sir Stirling Moss
mep
29
Re: Red Bull RB6
I would like to see their damper, bellcrank, spring, antirollbar arangement with pull-rod once.
Michiba
Michiba
Re: Red Bull RB6
zgred wrote:Image
Nice pics Zgred.
So is the actuator housed inside that larger connector between the two main elements?
Also, the smaller element gives a nice clue to the intended flow to the side of the wing.
volarchico
volarchico
Re: Red Bull RB6
Is there a reason that a few mm of leading/trailing edge of every element is left plain black carbon fiber?
lotus7
lotus7
Re: Red Bull RB6
volarchico wrote:Is there a reason that a few mm of leading/trailing edge of every element is left plain black carbon fiber?
Yep, stone chips on a painted surface( or decal for that matter) , especially if the paint is in the sponsors colour, gives negative image
marcush.
marcush.
159
Re: Red Bull RB6
Comparing the actuation with what we see on other cars this looks really tiny...i can´t believe everything could possibly fit in the flap and that little fin...may it be they just have one actuator in the middle between the wing stays and only have a
tube going outside to the fin moving the flap? I thought this would be anyways the best method ,saves one actuator and one thing less to fail..
mep
29
Re: Red Bull RB6
I guess they just don't move anything.
What are they allowed to move the whole wing or just the 3rd. flap?
I can imagine that very sensitive wings can get messed up when you just move a flap. Looks like they rather want optimized aero with very thin and complex structures than the ability to move a wing 2 times a lap.
It also reduces the weight of the wing.
I heard a comment on BBC that the Silverstone wing was much lighter than the old one to help getting the optimal weight balance. This should have helped especially Mark (sounds like he is heavier than Vettel).
marcush.
marcush.
159
Re: Red Bull RB6
that carbonfibre finish fat fin looks like it is housing something ..I was also under the impression they do not adjust their front wing ,but on a transmitted radio connection webbers raceengineer Pilbeam told Mark he could leave the wing adjustment alone as the telemetry showed it was stuck...I have to admit that was in one of the first races ..but also then you could not really spot the part containing the adjustment mechanism..
Re: Red Bull RB6
I think they move the inboard part of the 3rd (rear-most) flap. If you look very carefully just to the right of the smaller of the two arched connectors (connecting 3rd to 2nd flap) you can see a couple of fasteners. There is also a very faint line running from the obvious split in the 3rd flap down next to these fasteners to the leading edge of the flap.
I think they have an axle-style pivot point there and the rest of the load is carried by the large carbon covered arched articulator.
Pierre6
Pierre6
Re: Red Bull RB6
Hey guys!
Just heard Brundel say something about the front wing of the redbull flexing and this being investigated by the FIA ? What is this all about? Can somebody give some technical explanation what they are examining?
Cheers!
Lorenzo_Bandini
Lorenzo_Bandini
Re: Red Bull RB6
Ferrari too have a front wing mobile
jason.parker.86
jason.parker.86
Re: Red Bull RB6
You think Vettel's wing falling off in Silverstone was anything to do with the new flexible wing row? Apparently the whole thing moves.
fenix4life
fenix4life
Re: Red Bull RB6
while looking at the race you could clearly see the flex while arriving at the hair pin. While breaking you could see the winglet going back up. It was as clear as a few years ago with ferrari where the front wing detached from the nose cone at full trothle.
But, as the flex is measured with a weight before and after the race it's ok.
It's a bit the same stories at with the Michelin tires. During the tests they were ok but apparently not during the race. It this cheating. Not sure.
