My F1 car - Pascaljackson
bajan-f1
bajan-f1
Re: My F1 car - Pascaljackson
I got a problem with the MEGAUPLOAD link. When I go on it, it says; "The file you are trying to access is temporarily unavailable."
Any ideas?
pascaljackson
pascaljackson
I have no problems, may i can upload it on another site.
bajan-f1
bajan-f1
No, not to worry, I've got it working now, thanks though
pascaljackson
pascaljackson
just a little request
would it be allowed to place flaps in this red area? i would take advantage out of the 75mm rule. for sure just above the diffuser
pascal
Shrek
Shrek
I would think so
Spencer
It is legal, you are allowed to place wings anywhere on the car within that rule if im correct.
You see those central slots on a F1 car, these fall within this rule, so you can place as much wings as you want there.
Also. i would remove the upward piece of the engine cover, it would be draggy and probably just create turbulence due to its placing.
I love the wheelcover though, seems really complex.
pascaljackson
pascaljackson
so some updates here and there
rebuild the frontwing a bit
simplified the rearwing, reworked the exhaust, added a wing in front of the beamwing
like announced, i used the middle section for my diffuser... may its not legal, dont know :)
now it looks a bit like the old diffusers, just not that big
pascaljackson
pascaljackson
I misunderstood the movable rearwing, i thought the lower wing will be moved, but its the upper...
and i adapted the diffuser to 125mm hight, and added two wings for more efficient
now im wating for a guy who may do some cfd tests, (if it works)
SiLo
139
Looking forward to seeing the results of the CFD test!
Felipe Baby!
