Ok new upgrade, i started on the 2011 car and built the tub
It is a totally new car actually, the tub is completely different and sidepods will be too, i decided to go for a more triangular sidepod shape so i can get more air around the sidepod.Also i will probably let the sidepods slope down the same way with the exhaust exiting at the back really low so it wil actually blow over the diffuser.
The nose has raised a lot, it is like twice as high so i could free up space to fit in a front splitter(not built yet).
I still have a few ideas wich i dont know if they will be legal or work, i wanted to make some sort of second plate on the diffuser, letting the exhaust blow in there to make an exhaust driven diffuser like Red Bull, by this i think i can create alot bigger low pressure area for the diffuser to act on with smaller gurneys. Also the rest of this area will not be affected by the exhaust gasses so i can go for a much cleaner rear end.
Also i have an idea for the F-Dcut replacement, it will not connect to the rear wing, but it will extend 15cm wide and blow into a slot under the rear wing wich will expand to a full slot. pretty hard to explain though lol.
Also i will try to go for an as low as possible CofG, thus an really low crashbox and red bull style pushrod suspension.
And last but not least i am trying to make use of the central 15cm as much as possible, extending the diffuser there for example, putting in wings there
An completely new idea i had simply removed most of previous ideas, on the sidepod area it is regulated about air exhaust, but it is not regulated as an air intake, so i wanted to make the sidepod higher to regular height and then make an huge vane in it, from the side you cannot see what is behind it, there the bodywork will stop, leaving huge amounts of space for radiator exit cooling, on the intake i wanted to make a few more coolers, helping the low CofG as the higher placed sidepod radiators can be smaller as it is divided into more of those. I hope this idea is understood correctly and someone can tell me if it will be legal, if it will work and if it has potential. Personally i think that if it is done correctly it can draw alot of air back into the diffuser area increasing downforce and with that it will reduce drag as less air will collide with the rear tire and less rear tire influence. I can also draw that area really far back in front oft he beam wing and simply close this area from the rear wheel.
In this space i have alot of space for pullrods etc. as it is really wide and i can do in this area what i want as it isnt seen, so i can simply place the suspensin in positions that were never possible before
