I'm afraid that I'm with Edis here riff, when torque capacity can be simplified as follows;riff_raff wrote:Dave Killens,
Friction clutches are designed by thermal capacity, and not so much by an ability to transmit torque. If torque transmission was the only concern, then a single clutch plate could be made to work by increasing the clamping force. The reason multiple plates are used is to provide enough thermal mass to prevent the temperature rise in the plates during slippage from exceeding safe levels for the CRC plate materials. The reason small diameter plates are used is to minimize the polar inertia of the clutch pack and to keep the engine CL as low as rules permit.
The AP drawing I linked is for a 115mm (4.5 inch) dia clutch, which is quite small. I believe current rules require an engine crank CL at least 58mm above the reference plane (ie. the underwing OML). So a 115mm dia (57.5mm radius) clutch pack would seem appropriate
Torque-max = mu * Axial force * (outer radius + inner radius/2)
If Torque is 300 Nm (750 Hp at 18k), OR is 58 and IR is 43 mm like the AP, mu set at 0.6, you need a force of 10 kN
to transmit the torque through one friction surface, 5 kN with two and only 1.4 kN with seven surfaces as the AP.
When looking at the very simple spring loading device of the AP-clutch, I would think that such a low clamping force
as 1.4 kN (320 lb) is most advantageous for packaging and almost everything else.
Come to think of it, the above is of course another reason to standardize crank centerline.
