ZF-Sachs F1 clutch internals, it´s not the latest model, but the concept is similar
Wear caused by oxidation is less of a problem with a clutch since it will soon cool off after the start.riff_raff wrote:xpensive,
Heat transfer and friction with carbon is a tricky subject.
As I noted, carbon-carbon definitely has an oxidation temperature limit. With a clutch pack, the heat is being generated at the sliding interface and must be transferred away from that surface. Pitch based carbon has good heat transfer in the axial direction, but poor heat transfer in radial direction. So getting a good heat conduction path out of a thick stack of rotors and stators can be troublesome.
With regards to Mu, carbon has a friction coeff. that varies with temperature. It is the opposite of most materials in that its Mu increases with temperature. Carbon clutches tend to slip very briefly until they heat up. Then the Mu increases and they quickly grab, almost like an on/off switch. That's why even very good drivers still occasionally stall leaving the pits.
Regards,
riff_raff
The F1 clutch is just an ordinary dry multiple plate clutch with carbon/carbon in all friction faces.autogyro wrote:Looks exactly the same as an automatic transmission clutch as used in many auto transmissions since the 1930's. It is just dry friction materials rather than wet.
No big deal at all.
Build a transmission casing out of light exotic materials.
Fill it with conventional but light weight gears in a combination based on an 1899 design. Operate the selectors with hydraulic or pneumatic rams electronicaly controled and you have an F1 gearbox.
Join a fully regulation controlled engine design to it and you have the complete F1 powertrain.
Now where on earth is the on going technical development in that?
