xpensive wrote:....WhiteBlue wrote:So what? Why should that be a problem for a company that has all the necessary technology and all resources?Pup wrote:Yup. All they'd have to do is add 30 horsepower, take out 2 liters, lop off a couple of cylinders, trim it down a few pounds, add a pneumatic valve train, double the boost pressure, and then redesign it as a stressed inline 4 - and bingo was his name-o.
Twenty years ago they approached F1 with the same very attitude as Mercedes had when entering group C, both with disastrous results, which was only a few years after Porsche had had monumental success in F1 with their 1.5 turbo V6.
Difference was that in 1982 they had to listen to John Barnard, but in 1989 Hans Mezger tried to do it on his own.
exp,have you worked in Weissach?
from my very limited insights I can fully underwrite your comments and see no sign of state of the art leading technology present in current Porsche products .
tbh,Porsche NEVER had that approach of technological leadership and the general approch is very conservative indeed(just think about the car concept -Beetle- prewar...)the approach inside is at the very best to be a fast follower on new technologies ...but what is this? applying the technology when anyone else has it?
Mclaren is introducing a carbon chassis when Porsche is changing from Steel to Aluminium structure...
If you have ever seen the current DI injection boxer engine in the flesh you would know what I mean that is a massive piece ...the counterpart of what you need in F1.
