Does anyone think it's possible we could see the RB X1 car in LMS soon?
It's very close to the current generation LMP1 cars minus the fan at the rear.
I wouldn't just say it hasn't an f-ductHolm86 wrote:I like i too .....
At first i thought it had an f-ductbut the fin seems to thin
Given the height of the rear body work, if the bias is wrong rear down force looks like it can easily be added. I imagine that the will use a 2-3cm gurney flap on the rear body work.wesley123 wrote:Indeed, and its balance is weird either, 53% on the front wheels, that isnt quite an regular distribution.
Overall I rather think this car is built for the ALMS, where top speed is much less important and front turn in(thus front balance) is.
Sure, but with the huge amount of d/f it seems to be generating such an gurney doesnt chasnge the balance from 53-47 to 47-53. Gurneys are only used to max the downforce and balance the whole package out perfectly.creedbratton wrote:Given the height of the rear body work, if the bias is wrong rear down force looks like it can easily be added. I imagine that the will use a 2-3cm gurney flap on the rear body work.wesley123 wrote:Indeed, and its balance is weird either, 53% on the front wheels, that isnt quite an regular distribution.
It should be noted that the Riley Technologies LMP2 concept sported this integrated legality fin/center support detail months ago. http://www.rileytech.com/Newsarticles/News.asp?Itm=24Formula None wrote:Clever integration of the swan's neck RW center support on the R18.
Seeing this:wesley123 wrote: I am just so sure that this car isnt going to be an Le Mans winner, certainly not given the much lower drag peugeot who got way better traction.
and seeing that it is Audi,LeMans Regs wrote: Hybrid vehicle drivetrain systems will be extensively allowed with the new regulations, which include kinetic-energy recovery systems (KERS; no push-to-pass systems - KERS in LMP cars must be activated with the accelerator pedal), as well as four-wheel drive (non-hybrid vehicles will remain two-wheel drive, specifically rear-wheel drive).
