Ofcourse the first part is true, but if it was the best(false), then why did they change it(to a lower blown wing element version)?;) Renault set the benchmark with the f-duct, no doubt.Tumbarello wrote:mclaren's was the only f-duct that was designed around the whole concept of the car, everybody else did it as an after thought. as such it, it was the best f-duct there was.ell66 wrote:
i disagree on the f-duct statement...all the top teams had one by the end of the year...if mclaren had any advantage...it was only a very small one at that point...as martin whitmarsh said himself.
I haven't heard any engineer who has commented to the effect that McLaren's f-duct was not the most effective one on the grid. I don't know where you get the idea that Renault had the best system from, I hope it's not all based around their performance in Abu Dhabi? Remember that Hamilton couldn't get past Sutil in Malaysia, either, and had a hard time keeping Petrov off his tail on the straights when the Renault didn't even have an f-duct!Donuts wrote:Ofcourse the first part is true, but if it was the best(false), then why did they change it(to a lower blown wing element version)?;) Renault set the benchmark with the f-duct, no doubt.Tumbarello wrote:mclaren's was the only f-duct that was designed around the whole concept of the car, everybody else did it as an after thought. as such it, it was the best f-duct there was.ell66 wrote:
I read somewhere that blowing the flap creates more stall, but is very abrupt, blowing the main plane is smoother in handling.Donuts wrote:Ofcourse the first part is true, but if it was the best(false), then why did they change it(to a lower blown wing element version)?;) Renault set the benchmark with the f-duct, no doubt.
and this with the miserable renault engine....I haven't heard any engineer who has commented to the effect that McLaren's f-duct was not the most effective one on the grid. I don't know where you get the idea that Renault had the best system from, I hope it's not all based around their performance in Abu Dhabi? Remember that Hamilton couldn't get past Sutil in Malaysia, either, and had a hard time keeping Petrov off his tail on the straights when the Renault didn't even have an f-duct!
With that ghoulish looking nosejob, you figure that Renault had power to throw away this season, but on topic;marcush. wrote: ...
and this with the miserable renault engine....the renault was also famous for its simplistic Aero all optimised for drag reduction..
No(don't assume things), the simple fact that they changed(Abu Dhabi) their f-duct to a version(Renault F1's)that blows the lower element, obviously beacuse they deemed it more effective.Tumbarello wrote:
You should practice what you preach. Don't assume that that only performance gaining part of the system is related to the part of the wing the f-ducted is directing air at. It could be that the Force India idea, copied later by Renault and others, of attaching the f-duct to the lower element, is optimal for that end of the f-duct but the rest of the system is more efficient in the MP4-25.Donuts wrote:No(don't assume things), the simple fact that they changed(Abu Dhabi) their f-duct to a version(Renault F1's)that blows the lower element, obviously beacuse they deemed it more effectiveTumbarello wrote:
Sauber 'had that idea' and applied it first.It could be that the Force India idea...of attaching the f-duct to the lower element...
