Basic principles of an F1 steering mechanism
anishhotpunk
anishhotpunk
I am reading the forum,for a long time.
I am interested to know how the F1 car steering,
I means where is the steering rack?
How different it is ?
What are key mechcansim to operate , geometry of it ?
Regards,
ANISH #-o
Reason: Removed capitals
scarbs
scarbs
393
Re: HOW F1 CAR STEER, MECHCANSIM , BASIC PRINCIPLE.
F1 steering systems are basically similar to Road Cars or any other race car. The steering wheel's attached to the column, which operates a rack&pnion steering rack, the track rods transfer the motion to the wheel\upright. F1 cars use a hydraulically assisted rack, while the column has a joint in it
(see the images below for a schematic and detail of the system.
Schematic
Column
Rack
Rack & Pinion
steering joint
anishhotpunk
anishhotpunk
Re: Basic principles of an F1 steering mechanism
thanks dear ...!
It seems you have great knowledge about the f1 developments. Thanks for helping me out.
regards ,
anish
anishhotpunk
anishhotpunk
as shown in the pictures (1st one), people talk about the differnet aspects of steering in F1, like aniti-ackerman, ackerman. what is the use of this knd of geomtry, how teams make decide what to use or not to. speacially , do we have to consider the equation of suspension geomtry in implementing the steering mechcansin etc. please throw some light on these aspects.
mep
29
Maybe we should make an ackerman topic.
anishhotpunk
anishhotpunk
vaibhav
vaibhav
scarbs wrote:
02 Jan 2011, 14:11
Schematic
http://scarbsf1.files.wordpress.com/201 ... ematic.jpg
Column
http://scarbsf1.files.wordpress.com/201 ... column.jpg
Rack
http://scarbsf1.files.wordpress.com/201 ... t_rack.jpg
Rack & Pinion
http://scarbsf1.files.wordpress.com/201 ... pinion.jpg
steering joint
http://scarbsf1.files.wordpress.com/201 ... gjoint.jpg
So, can you tell me, how they are operating rack with hydraulic in this small design???
I mean what is the cut section or design of the F1 steering rack and pinion with a hydraulic system looks like???
strad
117
??? you confuse me. It works like any hydraulic system.
Sir Stirling Moss
The hydraulic pump fills a chamber either end of the rack and pinion gears, as the chamber fills it pushes the gears in either direction.
scarbs
scarbs
393
F1 power steering rack Image
http://imgur.com/gallery/QkOJcGH
The basic unassisted rack and pinion set remains the same. F1 racks must be mechanical and no electronic aids.
There is a hydraulic valve (left of centre - green), this uses some compliance between the pinion and rack, the small amount of movement shifts the valve and that directs hydraulic pressure into the actuator to help move the rack.
The compliance comes from the grey 'M' shaped spring, which positions the pinion against the rack. Ateams will tailor this to give the driver the feel they need.
Greg Locock
Greg Locock
238
Fun fact. In a conventional hydraulic rack and pinion steering system both sides of the piston are at full pressure. One of them gets exhausted to give pressure differential across the piston.
Ackerman. There more than 3 theories on this. Theory one is that it is all too complicated and you should just use parallel steer. Theory 2 is that the the inner wheel should be oversteered to increase the yaw moment on entering a corner, by causing drag on the inner wheel. Theory 3 is that the outer wheel is more heavily laden and will reach its peak slip angle at a different steer angle than the inner, and so the steering should be set up to optimise both. Theory 4 is that static toe behaves much like Ackerman.
Sebgamer
Sebgamer
scarbs wrote:
02 Jan 2011, 14:11
Schematic
Column
From the image it looks like a single universal joint on the column, which means the steering would be non-linear. Is this the case in F1? Or is a CV-joint used?
Greg Locock
Greg Locock
238
Single UJ does give a non linear steering gain, but so long as (in the simple case) the cross is vertical and horizontal the non linearity is symmetrical about the straight ahead position.
