Sequential fork control drum
Brian.G
Brian.G
334
F1 Ra106 sequential transmission fork control drum,
The notches, allowing insertion with forks installed.
Possibly the most beautiful Motorsport part Ive ever held in my hand.
Measures just 200mm long, and 35mm in diameter. (Approx)
Brian Garvey
If you think you cant, you wont, If you think you can, you will
bettonracing
bettonracing
Re: Sequential fork control drum
Thanks for posting the pics (with included reference!).
I'm a little surprised the holes aren't cast into the body, given the part's complexity & the resulting sharp edges of post-processing, but I guess considering they didn't have significant "gearbox problems" drilling must work.
Regards,
H. Kurt Betton
Brian.G
Brian.G
334
Indeed.
Although holes have high surface finish and are de-burred both externally, and internally.
BG
Formula None
Formula None
Beautiful part. Thanks for sharing.
forty-two
I know this statement makes me a sad man, but that's exactly the sort of "art" I like looking at. Given the choice between that and a Picasso, I'd choose the part every time!
The answer to the ultimate question, of life, the Universe and ... Everything?
Tim.Wright
330
Pure porn. how much does it weigh?
Tim
Brian.G
Brian.G
334
Tim.Wright wrote:Pure porn. how much does it weigh?
Tim
@Forty-two, too true, and agree fully! Mona Lisa my ass!
Tim, my engine part scales is in for calibration, wont have it back for a week, Ill check then. Its not unbelievably light or anything,but it is light.
It also rings like its forged and not cast.
240
It appears to be forged, judging by the surface.
johnny99
johnny99
Hello Brian, how are you. Where did you get hold of that
John
Brian.G
Brian.G
334
johnny99 wrote:Hello Brian, how are you. Where did you get hold of that
John
John, Ill email you the place. I dont know if posting links to traders is allowed on here, so wont chance it.
riff_raff
riff_raff
132
ringo wrote:It appears to be forged, judging by the surface.
Ringo,
It's not forged or cast. It's machined from bar. Likely a chrome-moly steel such as 4340 (or EN40 for those of you in the UK).
First, its OD and ID are rough turned/bored on a lathe. Then the cam grooves, detents, and radial lightening holes are machined on a 4 or 5 axis CNC mill. Then the internal spline is cut with a shaper machine. And finally, the bearing journals are finish ground. It may also have undergone some sort of surface treatment/coating for wear reduction.
Regards,
riff_raff
A: Start with a large one!"
tok-tokkie
tok-tokkie
38
To me it looks more like a lost wax casting with a little finish machining. The wax model grown by rapid prototyping machine.
riff_raff
riff_raff
132
Nope. It's machined all over. You can clearly see the lathe turning marks and the surface mismatches from the ball end mill passes.
riff_raff
Formula None
Formula None
Riff, the machining marks on the outside are clear as you point out. What about the ID in the middle being larger than at the ends, are you sure it was also done on a lathe? It seems like quite a reach for the cutting tool, getting inside there.
Couldn't it be forged into a preform then machined (similar to a piston) riff raff? it looks forge-ish to me too. I know it's machined but wouldn't you make this from a roll forged bar?
To Brian.G, You have the other parts?
