Williams FW33
csponton
csponton
Re: Williams FW33
WILLIAMS
http://spontoncristiano.wordpress.com
Unlike the Lotus-Renault, the FW 33 is a project that will undergo significant changes before and many of the opening race in Melbourne. For this, Barrichello and Maldonado, will surely benefit from this delay of 2 weeks. Williams will completely change many details of the car: rear, front wing, diffuser, brake ducts, baffles, and part of the body. KERS in these tests did not work very well for overheating problems. The Team will use this week to remedy the situation and use the best for the inaugural Grand Prix.
WILLIAMS
1.14,299 Maldonado Valencia 12 °
Jerez 1, 1.19,832 Barrichello
Barcelona 1.24,008 Barrichello 11 °
TOTAL 3,787 KM
zgred
Re: Williams FW33
Raptor22
Raptor22
26
Re: Williams FW33
notice in the backgorund Mercedes W02 fitted with 2011 nose cone.
Re: Williams FW33
Edit.
FW17
171
Re: Williams FW33
Is there some sort of display going on? There is also a old Williams in that shot
zgred wrote:Image
bot6
bot6
Re: Williams FW33
I think that's just an older car that's there for the public. There's an old Williams on the right too...
Raptor22
Raptor22
26
Re: Williams FW33
yip its an older car. A modified 2008 Honda apparently
roadie
39
Re: Williams FW33
So, more KERS issues keeping the car in the garage. Certainly disappointing, as I was hoping they'd sorted KERS in the time between now and the last test. I'm certainly looking forward to seeing more photos. Does anyone think in the photo above they have opened up the rear of the car for cooling?
horse
Re: Williams FW33
roadie wrote:Does anyone think in the photo above they have opened up the rear of the car for cooling?
Yes, that whole part of the car now appears to be open where it was almost fully closed at the last test.
zgred
Re: Williams FW33
raymondu999
Re: Williams FW33
zgred wrote:Image
Is that a crack above the exhaust?
失败者找理由,成功者找方法
roadie
39
Re: Williams FW33
Certainly looks like damage. Car stopped again today, and it's not running KERS. I'm so hopeful that they can get all reliability issues sorted before the first race, as the FW32 was extremely good on this front.
scarbs
scarbs
393
Re: Williams FW33
I think thats broken paint around an aperture made for an IR sensor. In early tests Williams ran a sensor strapped to the RTWB, I'd guess this replaces that, to measure tyre sidewall temperature
forty-two
Re: Williams FW33
The metalwork behind the exhaust outlet seems to discolour and change to a matte finish rather a lot.
I wonder if this is an interim solution while they work up a temperature resistant part, perhaps some sort of ceramic coated CF?
The answer to the ultimate question, of life, the Universe and ... Everything?
Onch
Re: Williams FW33
I do not think the discolouration is any cause of concern...
The exhaust gases also contain burnt oil etc. that will generate a matt layer on the surfaces nearby, but it's just aesthetics.
