If this is your 1st post, then note, this a forum for the discussion, exchange of ideas etc re everything F1 (including alot of technical and other related stuff). We all come from different places and do things or think differently. We also frequently disagree with each other on many issues and some know more about certain things than others. But even in our disagrements we still learn (at least I do) from each other. What I did not think this forum is (was) is a place to post insults, silly comments about what you know or do not know, what you are or are not, or make derogatory comments about certain peoples.todays no ones use imperial mesures to design engines, every ingeneer use SI mesure and all use Newtons and not Lbs!
Hope if you are englishman that you know who was Isaac?
and that you'll leave Lbs to calculations of potatoes!
bye
If you really are an engineer then you will know that though most engineers are taught in SI units or both (possible exception being the U.S), not every engineer designs in SI units as you claim. It all depends on specific industries or your markets.
If you disagree with:
Then please just say so or show so. Its simple and perhaps we will learn something. The old saying that "you cant teach an old dog new tricks" is rubbish and not true. What is true however is that "you cant teach an old foolish dog new tricks". Why? Because only a foolish dog thinks it knows all there is to know about anything and is therefore incapable of learning anything new.
So 1hp = 746kW ? not 746 Watts?
