Actually reference plane is 10 mm above the plank, so if at the same time wing and plank touch the ground, wing has to be below reference plane. By 10 mm to be precisely.Lindz wrote:Let me put this out there: if you can't have any bodywork below the reference plane, but you run enough rake on your car that the reference plane touches the ground during decent compression in front of the front wheels... how is your wing being close (even touching) to the ground illegal? It's not breaking the reference plane.Ferraripilot wrote:I see your point of view, but there is a difference between rhetorical interpretations of a rule and outright breaking the rule (2 rules actually) by making a mockery regarding how the rule is enforced which is what RB is up to.
What part is is outright breaking?
And:
So it will be 75 + 10 = 85 mm.3.7.1 All bodywork situated forward of a point lying 330mm behind the front wheel centre line, and more than 250mm from the car centre line, must be no less than 75mm and no more than 275mm above the reference plane.
You don't need high res photos to distinguish between 0mm and 75mm
And i don't buy this arguing about to much stiffness will break the wing. There are at this very moment some airliners up in the sky, with 500,000 kg of load on the wings, flying at serious speed in turbulent air, barely bending that much as RB7.
