beelsebob wrote:n smikle wrote:Interesting...What sort of advantage do you mean? His last wet race was horrendous!
His ability to judge when to switch to what tyre – every single time we've had a race where the tyre choice has been non-obvious, button has always been on the right tyre at the right time. Tbh, I think this is pretty much the one area where Hamilton could learn from him.
And the one race where it was, he fuffled the race (Korea)
WhiteBlue wrote:BetFair has no manual setting of the bets. The odds are set by a computer that matches the amount of money set on the drivers. The bookmaker always gets a certain cut of the winning, whoever wins. That way the automatic algorythm creates the fairest representation of the betting money's expectations.
The odds have been often correct in the past, but sometimes unexpected results happened. Vettel's engine failure in Korea and Hülkenberg winning qualifying in Brazil were such cases. Most other races and quallies were won by by Vettel as expected.
I understand that the odds of the winning/pole driver would be shortest, but statistically, how many times have the order been 100% matched? Or very close? I mean from 2nd-24th. If that makes sense.
Shrieker wrote:I never looked at it that way. Now thinking, hot exhaust gases blowing towards the ground - in front of the rear wheels- really might give an advantage !
That's if it were inter conditions, then they'd have traction with slicks. But what if it were wet though? Could they blow-dry the track to the point where it's too dry for the rears or too wet for the fronts? (if they use inters/wets)
