I don't understand this vague "explanation" at all.Jersey Tom wrote:Throttle is easy to scale, it's known that it will be 0-100%. Brake pressure on the other hand can be... whatever. Easier to do with an on/off switch and display.
To be honest, given the inaccuracy of guessing rev based on audio when there's so many other cars about the place, I'd guess they have a (likely limited) feed of team telemetry.andrew wrote:Does the acceleration not go on the volume?
Braking would be nigh on impossible for the TV broadcasters without tapping into the teams telemetry.
Well, something that is 'vague' to one person can be deemed 'concise' by another. To say what JTom said, but in more words:Hangaku wrote:I don't understand this vague "explanation" at all.Jersey Tom wrote:Throttle is easy to scale, it's known that it will be 0-100%. Brake pressure on the other hand can be... whatever. Easier to do with an on/off switch and display.
It's a valid question - the brake is still being applied somewhere between zero and one hundred percent, so why isn't it being shown as this?
Sure I understand all of this, but brake pressure for each car has to be measured somehow, if it's with bars of pressure or bars of chocolate it doesn't matter, it's still a certain percentage of the maximum achievable pressure. Sure, that's a variable, but you would expect it to be available to the guys that do the race overlays.Mystery Steve wrote:Well, something that is 'vague' to one person can be deemed 'concise' by another. To say what JTom said, but in more words:Hangaku wrote:I don't understand this vague "explanation" at all.Jersey Tom wrote:Throttle is easy to scale, it's known that it will be 0-100%. Brake pressure on the other hand can be... whatever. Easier to do with an on/off switch and display.
What is 100% of brake application? The upper threshold is only dependent on how hard you can push the pedal; the measurement is force-based. The throttle, on the other hand, has a clearly defined stopping point; this measurement is position-based.
Hypothetically, you may be able to back out a calculation of the maximum line pressure if you knew what the line pressure would be based on the master cylinder size, the brake pedal mechanical ratio, and the maximum (arbitrary) force that the driver can possibly apply, but that value wouldn't have any intrinsic meaning. If two cars have different master cylinders and brake pedal setups, they could hypothetically generate the same braking force at the tire while requiring different inputs from the two drivers. On the contrary, wide open throttle essentially means the same thing regardless of which car is being driven.
Such a value doesn't exist, as explained above.the maximum achievable pressure
It's not limitless. Don't be silly.beelsebob wrote:Such a value doesn't exist, as explained above.the maximum achievable pressure
It's limited by only the strength of the driver's leg... Given that there's no rule capping how strong a human can be, it is effectively limitless. The only thing you could possibly do is make assumptions about how strong a driver could possibly be, but you're likely to be very wrong. It was recently shown for example that one driver (who shall go unnamed to save flames) was exerting 1.5 times the preasure on the break pedal than his team mate (who shall also go unnamed).Hangaku wrote:It's not limitless. Don't be silly.beelsebob wrote:Such a value doesn't exist, as explained above.the maximum achievable pressure
The difference is, different cars will have different values. It doesn't mean they can't be normalized to a percentage.
One thing you should never forget. Those TV viewers are the only reason you can do what you are doing because that's where the money actually comes from.Jersey Tom wrote:I'd want nothing to do with installing extra BS weight on my car with some linear pot on the brake pedal, purely for the pleasure of a handful of TV viewers.
