Having a driver throttle on in the braking zone as your are suggesting will not work as you think as it will create torque at the rear wheels and drive the car forward which is not what hot or cold blowing is. Hot and cold blowing is to do with burning fuel in the exhaust so no torque is created but exhaust gas is driving the diffuser whilst off throttle.bill shoe wrote:The James Allison article is the most specific public information we've had about the new engine mapping rules.
Based on public information, if the driver pushes the throttle pedal at least 1% into its travel then there is no restriction on throttle position, ignition timing, or anything else. Therefore, there is no change to blown diffusers IF the driver pushes the pedal 1%. All drivers use left foot braking which means the right foot is available for this throttle-cracking excercise during braking and turn-in.
I assume drivers and engineers are spending a lot of time practicing this technique on driving simulators at the factories. I assume teams will try it out on the cars during Friday morning practice in Valencia in advance of it becoming the new norm at the British GP.
Therefore, blown diffusers will not really be eliminated or significantly changed. The only difference is that drivers will have to do the silly keep-the-throttles-cracked thing during braking. This will be inconvenient, but if blowing the diffuser makes you faster then you really don't have a choice.
If I was strongly against blown diffusers then I would still wonder what the point of the new rules was. They seem too intentionally inept to make sense as an anti-Red-Bull plot. Therefore I assume they are a way for the FIA to remind people of its power and show that FOTA is submissive, sort of a probe into enemy lines ahead of the Concord negotiation battle.
Why do you think this is anything to do with the FIA reminding people of its power to fight in the concord negotiation battle? Its just trying to eliminate using engine mapping to effect the areo... It far from an inept way of stopping blowing diffusers and should stop cars being changed electronically under parc ferme conditions.
I just dont understand why a team cant enter its extreme quali down force map as one of its race maps and only run it in quali as driver change between about 6-10 maps through a race anyway with no need to reprogram with a laptop...
