mep wrote:Does anybody (Ciro Pabón perhaps)
know something about the exhaust pipes on two stoke engines.
Becouse I have to build one for an 2 cylinder boxer two stoke engine
for a model car.
I have never ever thought of making one for a model engine! I do not understand if you have a model engine that works, like the one they use on radio controlled aircraft, or if you are building a model car and you just want to create a pipe similar to the original. Whatever, this is what I know:
The information I used (with a friend, on his bike) was to build one expansion chamber for his RZ 350. He got an Excel sheet with the diagrams for the cuts and weldings by asking to Rickard Wänqvist, owner of the site where I got the diagrams I posted. His e-mail is
rpm@bredband.net. But this is an specific design for this kind of bike and tuning.
You have to google for your particular bike model, or maybe Mr. Wänqvist can guide you. This could be of no use if your engine has not been analyzed previously by some tuning fan. This analysis should include any modifications made to the carburetor or the ports. It is hard to believe the change you get in the engine power.
You can find several software packages, as RH1300S points out, that you can use to fit your particular model of engine. I have read your PC is far from having the power needed for designing an optimal chamber but these packages can be useful in a model car engine.
http://rcboat.com/anteng.htm Old program, developed in 1999, U$100, you can design your button head and optimal diameter and length of exhaust pipe. It is specifically designed for model boat engines. A friend I have who is nuts for model airplanes has a copy and recommended it, but I have never used it. He explained to me that he hasn't heard of expansion chambers, just pipes cut to a certain length and of a certain diameter.
http://www.users.bigpond.net.au/arrowka ... pe_dsn.zipSimple expansion chamber design program, from Ian Williams Tuning. Do not know if you can use it for small engines, but the price is correct: you can download it for free. The complete MOTA software costs AUD$ 250.
I hope you can do something and tell us if you can get any increment in power! Anyway, thanx. I will post these two links in my simulation software page.
