What is this embedded into the car's floor?
est1984
est1984
I am wondering what is that bulge that is in the middle of the picture above. I understand it is a carbon fiber surface but it seems to be some sort of sensor or hinge that has been embedded into the structure. Does anyone else have anymore knowledge regarding this?
Reason: Fixed spelling in title
Goran2812
Goran2812
27
Re: What is this in embedded into the floor...
temp sensor for the tires...
Visit my photo page! -> http://www.gorankphoto.com/formula1
est1984
est1984
They must be using those temperature sensors that use a laser to sense the actual temperature then? That is the only method I think would work from such a distance from my knowledge.
flynfrog
est1984 wrote:They must be using those temperature sensors that use a laser to sense the actual temperature then? That is the only method I think would work from such a distance from my knowledge.
I think they are IR
Polarbear
Polarbear
Yes, they are definately IR...
piast9
piast9
Laser mounted in handheld temperature sensors is used only to mark the point at which the sensor is aimed. The temperature reading is done by IR detection.
