Stripped F1 Gearbox
Crucial_Xtreme
Crucial_Xtreme
404
Stripped F1 Gearbox
Scarbs posted a picture of a stripped F1 gearbox at the AS show. Be sure to click full size picture, great detail.
http://a.yfrog.com/img736/2254/yukzy.jpg
riff_raff
riff_raff
132
Re: Stripped F1 Gearbox
Crucial_Xtreme,
Thanks for posting the picture. Definitely shows what a nice job of packaging modern F1 gearbox designers can do.
Hi-res photos like this are especially fun to look at for engineers. If you look closely, you can even see the wear patterns on the gear tooth flanks. For example, the two gears on the right side show wear patterns predominately above the pitch line, which would indicate that their profiles would benefit from some geometry optimization.
riff_raff
A: Start with a large one!"
NonNewtonic
NonNewtonic
which car is this gearbox from? Is from a car that had race for this few season ?
FW17
171
NonNewtonic wrote:which car is this gearbox from? Is from a car that had race for this few season ?
Virgin
Owen.C93
Owen.C93
177
How big is it?
Giblet
Giblet
The minimum gear thickness is 12mm, and based on Williams saying the longevity of their new gearbox was no problem since they could could have gone to much thinner gears, I will assume that these are exactly 12mm wide.
strad
117
Well if they could have been thinner then they can't be 12mm,,they would have to be at least 13mm. ;)
Sir Stirling Moss
mx_tifoso
mx_tifoso
How much does a modern gearbox weigh?
Guess.. 20kg?
scarbs
scarbs
393
IIRC Xtrac announced their 2009 gearbox was 24kg, so I guess a contemporary carbon case 'box is around 20kg or lighter
pgpada
pgpada
Is this gearbox used? cause i see no wear...
strad
117
then your not looking... :lol:
Sir Stirling Moss
allstaruk08
allstaruk08
instead of laughing at a new person here why not tell them were the wear pattern is?
strad
117
If you look you can at see the wear pattern on the gears teeth and on the shift drum as well...I think I see some wear on the shift fork but that might be light and shadow..
Sorry but that wasn't anything compared to what gets laid on some guys,,especially if you don't have a D.Eng. or D.Engr. or Eng.D. or Dr.Eng. or Dr.-Ing after our name ;)
Sorry pgpada shouldn't hand out what I've recieved..allstaruk08 is right
Sir Stirling Moss
pgpada
pgpada
strad wrote:If you look you can at see the wear pattern on the gears teeth and on the shift drum as well...I think I see some wear on the shift fork but that might be light and shadow..
Ok i don't mind. after all i can see the wear on the shifting mechanism but you were referring to the gears also. after all the shifting drums really don't take their maximum loads in the direction of the towards the center, and this kind of wear could be done by just a simple test.
So except from these the gears seem brand new... and of course the speculation about tooth optimisation is empty.
