Sauber C31 Ferrari
n_anirudh
n_anirudh
Re: Sauber C31 Ferrari
Bazza wrote:
n_anirudh wrote:...
W wing for Sauber
Multi-element for the diffuser central area and brake vents
Hang on, what's going on under that diffuser? The two roundish things just off-centre?
Just diffuser vanes...I have never seen a multi-element section in the central 15mm..esp in the starter hole area..
Oneshortplanck
Oneshortplanck
Gusgus wrote:
Oneshortplanck wrote:my money is on it being some sort of hidden front wing,
air scooped from under the platypus nose, and exits on top surface.
You can't have that since 2009, no hole permitted in the nose area apart from one at the tip for driver cooling.
boooo! to rules
i thought i saw some scoops!
wang your contrast up, and you will see the scoops if you want to see them!
http://cdn.f1zone.net/news/wp-content/g ... _hires.jpg
Do not argue with an idiot. She will drag you down to her level and beat you with experience.
gibells
gibells
I should think the air from the cockpit may feed it. As Horse suggests.
FrukostScones
240
redbull clones, all of em. :lol:
Anyway this car has a pseudo Merc W02 nose style. The underside is a direct copy.
There is a minimum cross sectional area rule, so to get the thin nose, it has to be very wide to keep the area above the minimum, hence the platypus look.
All these cars look like winners.
neilbah
neilbah
Looking at the rear photo, despite the car looking quite well lined up the crash structure doesn't look symmetrical around the light. Nice thinking by sauber on the nose outlet though
n_anirudh
n_anirudh
rear crash structure looks bulky...??
Owen.C93
Owen.C93
191
n_anirudh wrote:PIC
It's asymmetrical as well which makes me think it's either testing equipment or an attachment for the starter-motor to hold on to.
Reason: Removed quoted pic (see above)
dren
228
I think the shadow from the rear wing is playing with things.
Honda!
Callum
Inlet and outlet for the "blown" wing? Just a complete shot in the dark. Nothing to back myself up.
dren
228
The wing is supported from the top to allow air across the full length of the bottom. I don't think it is blown.
Honda!
Owen.C93
Owen.C93
191
dren wrote:I think the shadow from the rear wing is playing with things.
Nah, this time the asymmetrical rumors are true :P
NonNewtonic
NonNewtonic
Callum wrote:Inlet and outlet for the "blown" wing? Just a complete shot in the dark. Nothing to back myself up.
Could it be a passive blown beam wing? I remember Mercedes for having those outlet when they are running the passive F-duct
raymondu999
Which asymmetrical rumors are we speaking of again?
失败者找理由,成功者找方法
dren
228
Well damn...I was looking at the side picture. Thanks for the correction. Looks kind of funky huh?
Honda!
