I understand what you are saying, and I agree. I am thinking the EBD generates more downforce at lower speeds due to the off throttle maps. You could make up for the lost downforce at lower speeds with your wings, but you would submit to much higher drag numbers. That was my thinking.raymondu999 wrote:Possibly. Again though - about helping with the brakes. That's because they had more downforce. The brakes didn't become better because of the exhausts - that's a function of the extra downforce afforded. If you get where I'm going with the differentiation. Again, I don't think the EBD could intrinsically change the handling/balance in a way that can't be countered - it just moved the setup window.
Since it was noted that the Red Bull had a high top speed, perhaps they were running a lower drag set-up, which wouldn't help braking.
It is early days, all teams will surely make set-up adjustments.
