uzael wrote:Back in the early 90's, all manner of engines were run, V8's, V10's and V12's. There was always the discussion of torque vs hosepower, but since each is a function of the other I am confused as to what the advantage of each might be, given the same displacement, wherether it be 3L or 3.5L. Could someone enlighten me on this?
Let's use a 3.5L V10 vs a 3.5L V8. Using division, a 3L V10's displacement should be around 350cc per cylinder while the V8 will have a little more displacement (I didn't calculate it, but it should be obvious to anybody here). With this bigger cylinder, chances are that the stroke will be bigger in the V8 than in the V10, should the cylinders have the same, or almost similar, bore. A bigger stroke leads to more torque, but at the cost of higher RPM limits (the longer stroke adds vibrational and balance penalties to the crank, limiting its effectiveness). Try spinning an 8-track with your finger near the center of the record, and then after a while spin it backwards. Do the same with your finger at the edge of the record.
If we use a 3.5 V12, the size of the cylinders is even smaller than that of the V10, and its safe to assume that the stroke will be even smaller than that of the V10. It is possible that this V12 will use a smaller, and hence relatively, lighter connecting rod, which will make it easier for the crank to rotate. Of course, with this smaller stroke, the torque will suffer.
