Wheel Slip & Ground Sensors
hardingfv32
hardingfv32
35
Re: Ferrari F2012
bhallg2k wrote:You might be able to find some information here ( http://www.optimess.cn/?lan=1 ). That's the company who makes the sensors.
I was there, but everything seems mounted outside the wheels. This F1 pod must just be the laser with other instruments, accelerometer,etc., actually in the hubs and/or wheels.
Brian
bhall
bhall
244
Re: Ferrari F2012
Somewhere on this site - god knows where, though - there's a picture of an Optimess control box mounted on the front bulkhead, underneath the master cylinders, of some car. If you can find it, you might be able to get a model number and be able to find the specifics you seek.
Or you can ask JerseyTom.
Squall
Squall
Re: Ferrari F2012
How they reveal the wheel-slip from chassis movement relative to the ground?
Initially i thought it measures wheel slip with centripetal acceleration (accelerometer) and steering angle,and then it is possibile to detect wheel slip.
Correct me if i am wrong.
hardingfv32 wrote:
bhallg2k wrote:You'll see them on most cars in testing and on Fridays during race weekends.
Is a laser measuring the chassis movement relative to the ground?
Brian
Pierce89
60
Re: Ferrari F2012
Squall wrote:How they reveal the wheel-slip from chassis movement relative to the ground?
Brian
movement across the ground combined with steering angle data gives you perfect slip angle info
Squall
Squall
Re: Ferrari F2012
Pierce89 wrote:movement across the ground combined with steering angle data gives you perfect slip angle info
So, the laser instantly traces the trajectory of the car on the track?
But i have no idea how do this
Is possible that they use this type of laser?
http://en.wikipedia.org/wiki/Laser_accelerometer
hollus
Re: Ferrari F2012
Does it work the same way an optical mouse does?
TANSTAAFL
Jersey Tom
Jersey Tom
Re: Ferrari F2012
Well, not quite. But close.
In any event, for those curious about optical sensors... feel free to read up on them.
Squall
Squall
Re: Ferrari F2012
Very interesting, thank you!
Do you know how (the physical principle) a laser can measure speed?
raymondu999
Re: Ferrari F2012
I would think it can sort of track how much it has moved - then divide that by time. I don't see how a laser could measure speed per se - except if you're talking of something like a speed gun
失败者找理由,成功者找方法
Gridlock
30
Re: Ferrari F2012
You can also use lasers for non-intrusive airflow measurement, ie a virtual pitot tube but much more advanced. Wind turbines and FADEC flight systems (fly by wire) as well as drones use them.
#58
Jersey Tom
Jersey Tom
Re: Ferrari F2012
Squall wrote:Very interesting, thank you!
They do not use lasers. It is an optical velocity sensor.
italian
italian
Re: Ferrari F2012
Pitot Tube is used for measuring speed in F1.
A laser can measure speed with two different methods:
1) The instrument shoot a "ray" to an object and it analyzes the frequency of the ray that "returns" to the instrument. It uses Doppler Effect: the frequency of the ray that returns changes depending of the speed of the object.
2) The instrument measures how long a ray shot to an object does take to "return" to the instrument. It uses the kinematics formula of uniform motion: d=c*t
c= speed of light
t= time for the "returning" of the ray
"Two things are infinite: the universe and human stupidity, but about the universe I still have some doubts." Albert Einstein
raymondu999
Re: Ferrari F2012
italian wrote:A laser can measure speed with two different methods:
c= speed of light
Where would the ray shoot? If it were measuring time to return that would probably be a ride height sensor more than anything.
If you were to create a "speed gun" using doppler; where would you shoot? You can't shoot front/rear/sides because the walls etc would change.
失败者找理由,成功者找方法
italian
italian
Re: Ferrari F2012
Maybe I am wrong? :oops: From what I know, lasers measure the SPEED of an object with these methods. If I've made a mistake, excuse me guys, please.
raymondu999
Re: Ferrari F2012
No no; the concept is sound. The doppler effect you mentioned is how speedguns work.
I just don't think this is what's happening in this example.
失败者找理由,成功者找方法
