2012 Testing - Barcelona 2: 21-24 Feb
raymondu999
Re: Barcelona Pre-Season Test 2: 21-24 Feb
JET - I wasn't commenting on Red Bull vs the field. I was commenting that Vettel in an RB8 on hards, on a 24 degree track surface, came 1.4s away from the 20.9 pole time of the 2011 RB7 on softs, on 40 degrees of track temp.
失败者找理由,成功者找方法
dieguezzz
dieguezzz
raymondu999 wrote:JET - I wasn't commenting on Red Bull vs the field. I was commenting that Vettel in an RB8 on hards, on a 24 degree track surface, came 1.4s away from the 20.9 pole time of the 2011 RB7 on softs, on 40 degrees of track temp.
Exactly... it says "catch me if u can" all over it ;)
cirrusflyer
Wery consistant lap times for Sauber...
If flying were the language of man, soaring would be its poetry.
It's all about technology!
When you go fast, do not hesitate to go faster!
blokkie
blokkie
I still don't know where you all get that 24C° track temp .
16:14 Track temperature: 9.6°C
16:13 Ambient temperature: 12.1°C
14:20 Track temperature: 9.7°C
14:20 Air temperature: 13°C
12:38 Track: 8.9°C
12:38 Air: 11.8°C
09:14 Track temperature: 2.0°C
09:14 Air temperature: 4.9°C
I just like to know . Can somebody give at least a link ?
My reference is : http://www.gpupdate.net/en/testresults/ ... uary-2012/
Mr Alcatraz
-27
ray said
And FYI; I actually meant that post. a 1:23 from any car; taking maybe 1.5-2 off for the blown diffuser; is quite a feat.
Than you should have written it chief!
Oh no did I use a derogatory term for a Native American, or was I suggesting that you are a man of authority. Here try this one Joey. They use it a lot in New York City. "Get outa' here"! :lol:
Those who believe in telekinetics raise my hand
JohnsonsEvilTwin
Was it 40 degrees?
BARCELONA TEST DAY FOUR
MONDAY 21 FEBRUARY, 2011
21 degrees track temps according to Williams.
:wink:
Oh and The quickest time of 1.22:625 was set on the fourth day which is 6 tenths up from today...the first test of the day.
Everyone is holding back and these 2012 cars are quicker then the EBD loss would have us believe.
More could have been done.
David Purley
raymondu999
blokkie wrote:I just like to know . Can somebody give at least a link ?
Link: http://live.autosport.com/commentary.php/id/439
The last temperature point they made: 15:27 The track temperature has dropped a little further, to 23 degrees. Just 10 in the air. And for humidity fans, it's 36 per cent.
Was it 40 degrees?
:wink:
Yep - pole comes from qualifying; not tests :wink:
失败者找理由,成功者找方法
dieguezzz
dieguezzz
Was it 40 degrees?
:wink:
i think he means the actual Grand Prix, not 2011 pre-season tests.
JohnsonsEvilTwin
Why not compare like with like?
David Purley
raymondu999
Because I'm trying to compare how close the RB8 laptimes we're getting in testing are to on-the-limit laptimes of the RB7.
Compared to the max potential of the RB7; if we normalize the difference between the soft/hard by 8 tenths; which was Pirelli's intention for 2012; that means the time difference is 2.4-0.8 = 1.6s. (I made an error above - it should be 2.4 difference and not 1.4)
And that's without EBD and with a very cold track surface.
失败者找理由,成功者找方法
Mr Alcatraz
-27
JohnsonsEvilTwin
raymondu999 wrote:Because I'm trying to compare how close the RB8 laptimes we're getting in testing are to on-the-limit laptimes of the RB7.
And it would be distorted because Red Bull don't run test programmes during GP weekends.
I think you would learn more by comparing the RB8 to the RB7 at exactly the same time in their development process. Also, conditions would be similar as I have shown.
Not only that, but isnt Pirellis harder tyre different this year?
David Purley
bcoxa
bcoxa
blokkie wrote:I still don't know where you all get that 24C° track temp .
12:38 Track: 8.9°C
12:38 Air: 11.8°C
This site is what I use for kart track weather conditions, but it also covers F1 circuits.
http://www.myweather2.com/Motor-Racing/ ... rcuit.aspx
Has a track temp chart tab also.
http://www.myweather2.com/activity/hour ... 2&id=42274
I'm not an engineer, just an experiment.
bosanac1
bosanac1
Mercedes with hydraulic leak not good start
raymondu999
JohnsonsEvilTwin wrote:And it would be distorted because Red Bull don't run test programmes during GP weekends.
Better to compare to a benchmark that you know what they're doing; rather than one that you don't know what they're doing
I don't think so to be honest. The RB8 is probably closer to a Brazil-spec RB7 - EBD + butchered nose than it is to a test-spec RB7.
Paul Hembery states the harder will now be 8 tenths (which is the number I used) slower than the softs
失败者找理由,成功者找方法
