RicME Motorsport - RME-001
jordangp
Re: Formula Sketch - CAD Drawing Help
The bodywork looks nice, although the sidepods are too high. And your front wing looks a little thin, you should use aerofoil shapes.
RicME85
52
Right, still no input from the other guys :(
I have a design concept but Im struggling to produce the final product, be it perfect joins between components or fitting in the reg boxes.
Here is the concept anyway:
N12ck
RicME85 wrote:Right, still no input from the other guys :(
[img]http://www.otf2.com/forums/gallery/imag ... d=1677[img]
Not bad, When you going to launch your final car? :D
Reason: Removed image quoted from post above
Budding F1 Engineer
krisfx
krisfx
The starter pack for that sounds quite interesting, as a matter of interest, what modelling technique do you use and what software?
I have access to student versions of pretty much every cad software available so I might as well get to grips with the best one.
jordangp
When designing, you should design parts together, thinking about the flow and transition between them. Think of the car as 1 solid piece, not different 'parts' that way you get an understanding on how to make it flow.
Also you should NEVER design a part, and then try and get it to fit into the reg boxes. Always start with the reg boxes, with an open mind, and design into the space you're given. That way you can't really go wrong.
N12ck
Exactley!! thats how I do it!! Although my wheelbase is different, I always start with the tub, and create the nose and then work on the engine cover, then sidepods and mould it all into one and never just stick parts on :D
If you just stick components together, you end up with the issue with unwanted angles and unsmooth bodywork :D
Budding F1 Engineer
N12ck
Nice car, but where is the driver side head protection?
Budding F1 Engineer
RicME85
52
yet to be fitted, just like the suspension
jordangp
RicME85 wrote:yet to be fitted, just like the suspension
But the bot behind the drivers head is also part of the headrest, yet you have that fitted?
N12ck
I dont understand the order which this is being built in, I made the headrest all one part and then tapered it down,
Budding F1 Engineer
RicME85
52
Does it matter?
Im really not good at this but Im trying my best. Im learning as Im going, I only wanted info on the game but ended up having my arm twisted into joining.
The guys who said they would help have gone quite and Im trying to get the car built before the season starts on my own.
I started with the basics that were given in the started pack and due to the lack of skill have had to create bits and pieces from scratch and 'bolt' them on.
Its not the best car but Im trying.
N12ck
RicME85 wrote:Does it matter?
Its fine, I think its a fantastic first attempt, I just would have put the headrests on first :D
Budding F1 Engineer
RicME85
52
How do you do a livery on the 3D model?
N12ck
RicME85 wrote:[img]http://www.otf2.com/forums/gallery/imag ... d=1680[img]
render it and go into photoshop and apply the livery, :D I did it on Paint.net,
Budding F1 Engineer
