FW34 rear transmission assembly
hardingfv32
hardingfv32
35
1) What is the device in front of the mechanic's face? Suspension related?
2) The orange colored tube, lower right corner, is it a shock? Why no hoses to it?
3) Would there be an assembly manual with clearance, torques, etc.?
Brian
FW17
185
Re: FW34 rear transmission assembly
hardingfv32 wrote:1) What is the device in front of the mechanic's face? Suspension related?
Gear change manifold
MadMatt
MadMatt
125
Yes, they showed it and how it was manufacturer on a documentary recently about Williams ! :)
strad
117
Blow it up to 200% ;)
Sir Stirling Moss
hardingfv32
hardingfv32
35
Moog valve assembly then?
How about the orange shock like body?
Do you think someone makes up a manual?
Brian
elmerfud
elmerfud
You can get moog manuals easy enough, 95% of that photo is of 'bespoke' design.
In short, no cigar for rebuild manual.
If you ask F1snake nicely, or pay him some dollars, he has a trove of information on the 2007 honda gearbox.
He might not share, given the hard work it took him to gather the information.
elmerfud
elmerfud
Back in the 2002 there was heaps of vector spline rich pdf manuals from f1 part manufacturers.
Most are now wise to digital information sharing. (a vector spline drawing is nearly as good as having cad files)
Try Sachs, ohlins, penske google searches.
I had the rear shock in vector from the F2000/AP04 but lost it in a hard drive crash.
As far a sequential gearbox goes, buy a blown jap motorbike donk and pull apart the gearbox, similar design theory.
(plenty of vector rich jap engine rebuild manuals) HINT!
