Hi, can any one answer the following questions for me. I am trying to extract some hidden HP out of a unique few of a kind engine. it is a single overhead cam supercharged v 8 engine sporting 3 valves, 2 in 1 ex. I have been playing round with cams and timing, and would like to short-cut my development by creating a logical baseline/ starting point. I need it to rev/ make power up to about 12000rpm but have trouble making it go over 9000.
1. how does the overlap effect the RPM? the valves mesh too well and get huge cross flow.
2. as a general rule advancing and retarding a cam will have what effects.
3. Is the max lift all that important in multi-valve engines?
4. can I relate in any way shape or form, 2 valve cams, four valve cams or turbo cams to what I am looking for?
5. what changes need to b made cam wise if you go from a 2 valve engine to a 3-4 valve. ie would you drop the duration because there is less flex in in the valve train? reduce the overlap because of low lift flow?
6. Would any one like to hazard a guess at what opening, closing, overlap, lobe centre and duration?
also does a non symmetrical cam help an engine rev?
I know there is allot more information required to give an educated guess, but im at a point where I feel I have tried everything so far without exploring outside the standard realms.
the only thing I have to compare is a similar 2 valve combo. and so far it is not working well.
any advice would be appreciated.
