autogyro wrote:bigpat wrote:Having actually raced a proper RACING H pattern gearbox, having worked with sequential gearbox single seaters, and knowing a little of F1 technology, I can tell you a 80's or 90's box is NOT quicker than today.
I have used repaired and developed improved performance gearbox systems for over 40 years. Re read the post heading, I made no direct comparison to F1 technology.
The jury is out on when the fastest F1 shifts were in use. It is not the point.
bigpat wrote:Those boxes contained BIG gears, with a lot of rotational inertia, compared to the tiny gears of today. Also, flat changing is quick, but the dog rings still have to slide the 10-200 mm across to engage. With human effort, and play in linkages etc, 0.2 sec for a completed shift. A modern 'non-seamless' box can do it 0.05 sec. No arguement.
There were plenty of geartrains in use with similar gear weight to todays F1 gear sets. Your shift timing is 'wrong' I have timed manual gearshifts in dog ringed boxes at 0.08 ms. A grandmother in a shopping car could meet your figures of 0.2 sec.
bigpat wrote:Also, with the H pattern boxes, you always lose time going diagonally across the gate.
True but it is a loss of 0,02 ms at the worst for a skilled driver.
In anycase manual gearshift mechanisms are not limited to H pattern.
bigpat wrote:With a conventional box, you always lose drive through the shift, even flat changing. I change clutchless in a racecar, and only lift of say 15-20% throttle on an up change ( flat shifting is reckless, especially if you want reliability), but, there is a reduction of torque to the back wheels, compared to full throttle. A seamless shift sees no perceptible loss in torque measured at the back wheels.
There is NO potential difference in the mechanical shifting mechanism chosen at the hub for either manual or so called seamless shifting, it is the method of triggering the shift that varies and the design of the gear lever geometry.
In fact the 'seamless hub mechanisms are more complex and work in more than one direction and are potentially slower than a strait dog hub.
The seamless shift systems use engine cuts and clutch disengagement to 'smooth' the shift actuation. Where this modulation occurs other than at shift overlap it reduces the efficient transfer of torque through the system and increase the time taken to transfer torque. The shift speed is not decreased by modulation because the limit to shift speed is the rotational inertia of the input components, not the shifting mechanism.
bigpat wrote:Sequential and seamless shifts were NOT created to eliminate driver input of skill, as I believe gerachanging speed/skill is always over-rated by people( most of whom have never driven a race car). No, these systems were introduced (as with all things)because they are quicker in laptime, full stop.
Sequential shifting was a sensible improvement to manual gearshifting. I advised Garry Anderson on this very point for the first Jordans, where they used a 7 speed manual sequential geartrain. Seamless is simply a method to soften and control gearshifts sufficiently to allow a fast gearshift using automatic systems. In F1 cars are held to the ground with huge downforce and therefore do not suffer the unbalance the use of a close to 'sledgehammer' shift would otherwise apply to the car. Without huge downforce these gearboxes would make the cars undrivable.
bigpat wrote:It is a fact that an F1 seamless shift box reduced laptimes by up to 0.3 sec per lap over a conventional box. That is an average of 15-18 secs over a race, which is massive.
You have no data to confirm this and it is simply untrue. The shift overlap and engagement spike may be measures at between 0.05 and 0.08 ms but this does not take into account any powertrain modulation that effects the TOTAL time taken for the change between fixed ratios.
bigpat wrote:Personally I think today's drivers have it tougher. No they don't shift gears, ( but the cars are quicker which means more physical loading on the body)but they must have presence of mind to use all the buttons and knobs on the wheels, and activate all the systems on a modern GP car, at full speed, listening to someone in your ear. Also, tactics are much better understood today, with everything calculated down to the second, where they expect the edriver to punch out times like a machine.
Back in the day, it was more man vs man, and generally laptimes varied a little more. The sport wasn't as precise as it is now...
