+1MIKEY_! wrote:The best gearing gives you the highest average speed over the straight. If that means hitting the limiter half way along it or right at the end then that's what you do.
You are right, hitting the limiter sooner or later on a straight is purely based on the trade off w.r.t to car balance and set up. Simple physics states that the faster you get to your top speed the faster you will complete the straight. so what vettel did in monza was the best set up for his car. They already had the best downforce set up, hence RB could compromise and compensate for their lack of top speed by shortening the time it takes to travel the straight, this gave vettel a good set up for the fastest lap time he could. for example low traction would mean compromising the torque, hence acceleration rate as a high torque would cause wheel spin round corners and make the car dance around and lose time. So best set up would be to trade off torque for better balance and lap time. i guess what we saw in mugello was a hint that ferrari may have sloved the issue but remember mugello is for high speed corners and not low speed... so we need to wait for barcelona to see how f2012 cope with low speed corners and if there top speed is reached well before the straight compared to others then we could say that f2012 has found some good DF and balance...MIKEY_! wrote:The best gearing gives you the highest average speed over the straight. If that means hitting the limiter half way along it or right at the end then that's what you do.
I disagree. It's generally better to be fast on faster parts of a circuit than it is to be fast on slower parts, simply because a car covers more ground on the faster parts of a circuit. That's why the F2012's lack of top-speed is (was?) such a problem..poz wrote:Anyway is better to gain 5km/h on a slow corner that on a straight [...]
bhallg2k wrote:I disagree. It's generally better to be fast on faster parts of a circuit than it is to be fast on slower parts, simply because a car covers more ground on the faster parts of a circuit. That's why the F2012's lack of top-speed is (was?) such a problem..poz wrote:Anyway is better to gain 5km/h on a slow corner that on a straight [...]
That's ridiculous, its exactly the other way around.bhallg2k wrote:I disagree. It's generally better to be fast on faster parts of a circuit than it is to be fast on slower parts, simply because a car covers more ground on the faster parts of a circuit. That's why the F2012's lack of top-speed is (was?) such a problem..poz wrote:Anyway is better to gain 5km/h on a slow corner that on a straight [...]
Wasn't RBR gave away top speed in exchange of more DF in order to be faster in slow corner and that helped them win big time last year?bhallg2k wrote:I disagree. It's generally better to be fast on faster parts of a circuit than it is to be fast on slower parts, simply because a car covers more ground on the faster parts of a circuit. That's why the F2012's lack of top-speed is (was?) such a problem..poz wrote:Anyway is better to gain 5km/h on a slow corner that on a straight [...]
