Williams FW34 Renault
zoro_f1
-2
Re: Williams FW34 Renault
new rear wing similar like mclaren. :)
i hope this car will proove that williams are in the right direction. we never see pastor leading a race and also it is crucial to defend the position.
Image “The force can have a strong influence on the weak-minded”: [Obi Wan Kenobi]
marcush.
marcush.
159
different spacer -this is the most obvious difference...
(Spacer -famous quote of Boris Said when asked what was the problem with the car, explaining he was the issue with not having adapted to the car yet..)
zoro_f1
-2
240
Spencifer_Murphy wrote:
Pierce89 wrote:The question is if you believe they can get back to the sharp end(fighting for the podium).
So, do you?
I know the question is for manchild but my 2bits is that this car won't be fighting for podiums no. But I do believe, and I do hope, that it will be a step in the right direction. [-o<
Then again I thought that about the FW33.
Maybe the Renault engines will help?
:lol:
N12ck
N12ck wrote:Im actually excited about this car, I would love to see an above shot :D
I knew this car was a good one, although I think the turn around was down to the new Renault engine,
Budding F1 Engineer
Last years car was fundamentally a good one, bar the cosworth motor, as you say, it's just down to the much tighter packaging from that Renault motor letting their gearbox and rear end solution work as intended. Nice to see it paying off and what they can bring now in terms of updates.
Owen.C93
Owen.C93
191
In case you ever wondered what was inside a rear wing endplate.
allstaruk08
allstaruk08
never noticed the slot in the endplate before
jordangp
It looks as if several parts will need to be changed on Bruno Senna's car now, probably gearbox, or even engine, due to fire damage, as they were exposed during the fire.
Will they get a penalty if this is the case?
IMO the FIA should allow the change, because of the circumstances.
Owen.C93
Owen.C93
191
I think there was much more damage from the Schumacher shunt than the fire. Thar car looked fine, just a little dusty.
jordangp
Yes, but Schumacher's car is damaged, because he crashed it, whereas Senna's car is damaged from fire as well as crash damage. I think it would be unfair to give them a penalty, if the gearbox is fire damaged.
Trocola
Trocola
jordangp wrote:It looks as if several parts will need to be changed on Bruno Senna's car now, probably gearbox, or even engine, due to fire damage, as they were exposed during the fire.
AFAIK, you can change your gearbox if you have a DNF. And you can change your engine, because you have 8 engines for the whole season
Trocola
FrukostScones
Owen.C93 wrote:In case you ever wondered what was inside a rear wing endplate.
now I m hungry, did someone collect the honey? (is it paper honeycomb? meta-aramid paper honeycomb core?)
JiMbO
Notice anything about sennas tires?
FrukostScones
maybe blackened by MSC? otherwise :wtf:
