There are of course some relations obvious to the engineer, such as;mx_tifoso wrote:Changing the rolling resistance characteristics will not have a significant impact on grip? For some reason I doubt it.
I agree, that's why I didn't bring those parameters up to begin with.mx_tifoso wrote:Yes of course X, but we shouldn't add different sizes to the equation, or significantly different pressures.
Michelin talk a lot about this and I'm looking around for some good articles as we speak.
not really X..i learned that in m physics coursexpensive wrote:There are of course some relations obvious to the engineer, such as;mx_tifoso wrote:Changing the rolling resistance characteristics will not have a significant impact on grip? For some reason I doubt it.
- A wider tyre should have both higher rolling resistance as well as better grip.
- A lower tyre pressure will cause much higher rolling resistance but also a larger contact patch.
Hey Z, you are pretty good at copy'n paste from Wiki, eh?
@ Ray; I'm not certain that comparison is relevant?
They don't. You trade off one for the other, unless you find some new way of doing things that lets you get a little of both at the same time. The tricks to that are proprietary.amouzouris wrote:so here is my question... how do they engineer into the tire a high grip level but with a low rolling resistance??? they seem to contradict each other..
I'm shocked.Jersey Tom wrote: ...
well that was exactly my question what is that breakthrough that allows you to reduce rolling resistance without the trad of...and ofc they are proprietary (good one XJersey Tom wrote:They don't. You trade off one for the other, unless you find some new way of doing things that lets you get a little of both at the same time. The tricks to that are proprietary.amouzouris wrote:so here is my question... how do they engineer into the tire a high grip level but with a low rolling resistance??? they seem to contradict each other..
Just as well could be asking, "How do you make an engine more powerful and use less fuel?" You don't, it's a trade off - unless you make some fundamental efficiency gain.
A large portion of traction comes from energy loss (hysteresis) of the tread. Can read more on that topic here.xpensive wrote:To say that you can trade grip for less rolling resistance and vice-versa is a new one, at least to my humble self.
Rolling resistance comes predominantly from the tyre's hysteresis, which I tried to xamplify above, while "grip" is something different, stemming from classic friction "mu", as well as contact forces in the irregularities of the road surface.
Gee thanks, I'm sure the vast majority of the forum will study that piece in detail.Jersey Tom wrote:A large portion of traction comes from energy loss (hysteresis) of the tread. Can read more on that topic here.
First I'm too quiet, reserved, and cryptic... now too detailed?xpensive wrote:Gee thanks, I'm sure the vast majority of the forum will study that piece in detail.
But what you are doing is xpanding into secondary parameters such as energy-loss from rolling hysteresis heating up the tyres thus making them more sticky, of which I'm not sure was the topic this time, or am I at a total loss here?
