Honda F1 2012 model - karayaone
karayaone
karayaone
So I'm back again with a new model! yay! damn it seems like it's gonna be illegal again!
I'm still modeling a lot of things that need to be reworked, but I'm finishing it quite fast! Atleast I have managed to change some things that were really really far from the real cars, but Some things are still out of reguletaions (or completely useless
Anyway, I'll leave you here some images so you can judge by yourselves.
will post moar as soon as I finish more parts!!!
MemroableC
MemroableC
Re: Honda F1 2012 - karayaone
Oh man he strikes again with a beautiful wing, only problem is it is missing the regulated section in the middle.
If you would like I can export the regulated section of the wing to either max or .3ds for you
karayaone
karayaone
do it please! I can still change it! and you'll help me a lot for my next project (which will be a fully legal one xD)
bhall
bhall
244
I thought this thread was about something else entirely.
MemroableC
MemroableC
Here it is
This is only the drivers right of the regulated area all you have to do is mirror it to get the full length. The origin is going to be where the front wheel center line and car center line intersect.
mx_tifoso
mx_tifoso
Re: Honda F1 2012 model - karayaone
These are nice and all, but I would love to see what you're able to do based on the current regulations. Season long development as seen on other projects is quite impressive.
jordangp
Another issue is that your parts are too thin, around the endplate section. There's minimum thicknesses for the endplate and footplate, but I can't remember what it is.
karayaone
karayaone
i''ve decided to convert my current project (this one ) into a legal one. I'll have to do some major changes but i suppose the result may be better. Apart from the official regulations and the apendix, do you have or know some sort of scheme or blueprint something that I could use to match the dimensions perfectly? working in 3ds max is not always the best when it comes to dimensions, but I will try!
If someone could give me a random total lenght? It would help me so much!
Cuky
65
if it helps, here are few examples of dimensions which can be found here on this site
Filliams FW34
Weight: FIA Minimum
Wheelbase: FIA Maximum
Overall length: 5000mm
Overall height: 950mm
Overall width: 1800mm
Sauber C31
Length: 5.195 mm
Width: 1.800 mm
Height: 1.000 mm
Track width, front: 1.495 mm
Track width, rear: 1.410 mm
Weight: 640 kg (incl. driver, tank empty)
Lotus E20
Front track: 1450 mm
Rear track: 1400 mm
Overall Length: 5038 mm
Overall height: 950 mm
Overall width: 1800 mm
Overall weight: 640 kg, with driver, cameras and ballast
krisfx
krisfx
MemroableC wrote:Oh man he strikes again with a beautiful wing, only problem is it is missing the regulated section in the middle.
Do you by any chance have this neutral section in a solidworks file?
MemroableC
MemroableC
Why yes I do
Same deal drivers right and origin is intersection between front wheel center line and car center line
karayaone
karayaone
thanks a lot Cuky!!!! I'll use those dimensions!!
GTO
So what makes this a Honda?
karayaone
karayaone
the fact that I want it to be Honda :) . It could be anything, but I like to make models that are not In actual f1.
karayaone
karayaone
Hey! Been working on legalizing my f1... hard to do, lot of things were wrong... but I've been fixing them!
I Was working on my exhaust and I couldn't figure if my solution was Illegal or not.. Maybe you could help me a bit?¿
Forget the details and verything else, not finished yet. just want to know if this kind of exhaust would be permitted?
Thanks in advance!
