Lotus E20 Renault
FakeAlonso
Re: Lotus E20 Renault
nacho
nacho
They could have more than those.
Gridlock
42
Those dial labels in full, from top centre clockwise:
CLUT
TYRE
VISOR
HS (or IIS?)
DRY
DISP
BIAS
KNRO
INSRT (?)
SCA(obscured)
AERO
DOWN
UP
FAIL (useful on first laps?)
12 buttons, 9 dials.
#58
raymondu999
Neno wrote:i wondered if team decided to race with high front downforce wing, and low downforce rear wing. what can you gain in this configuration? too much front downforce over rear can hurt car stability?
i know last year they brought special front wing for canada race, and it didnt work out well, to low downforce numbers. and because of that they had problems in race.
Perhaps one wing has a better L/D ratio - but has issues when cranked to a low downforce wing angle? And so they have to run a wing with a slightly more inefficient L/D ratio, but more suited to the track layout's characteristics?
失败者找理由,成功者找方法
Red Schneider
Red Schneider
Gridlock wrote:[img]http://static.ow.ly/photos/original/GhLm.jpg[img]
CLUT
TYRE
VISOR
HS (or IIS?)
DRY
DISP
BIAS
KNRO
INSRT (?)
SCA(obscured)
AERO
DOWN
UP
It's HS. I'm also quite confident it's INSRT, and probably either SCAR or SCAF.
How does this center dial work? Does it alter the display readout, and the values are then adjusted with the orange +- buttons?
I wonder if they could put up to 8 buttons on the reverse of the steering wheel that would fall right under each finger. That would be pretty instinctive once memorized, not to mention not needing to look down at what you're doing. Maybe there's no room what with the paddles though.
vikram_d
vikram_d
Noob question. What does the VISOR thing do?
Robbobnob
Robbobnob
33
vikram_d wrote:Noob question. What does the VISOR thing do?
goes on the front of your helmet, stops the wind from getting in your eyes. Quite handy at 200+ Mph
On the steering wheel, perhaps increases display brightness?? Your guess is as good as mine
FrukostScones
To avoid visors misting up, these days drivers have an electrical element in the visor for wet or humid conditions, which is connected to the car, so when the visor begins to steam up, he pushes a button on the steering wheel and it demists the visor.
http://www.jamesallenonf1.com/2012/03/h ... aysian-gp/
rkn
The one on top of the dashboard helps air over the helmet, both for aero efficiency and driver comfort
Owen.C93
Owen.C93
191
And they'd be a button for that on the steering wheel? I think it's for demisting.
Red Schneider
Red Schneider
I think RKN is referring to the very tiny windshield on the Lotus.
Owen.C93
Owen.C93
191
Red Schneider wrote:I think RKN is referring to the very tiny windshield on the Lotus.
I know, but VISOR is an option on steering wheel which was posted just before, so he was asking what that was.
MarkedOne8
MarkedOne8
Gridlock wrote: Those dial labels in full, from top centre clockwise:
CLUT
TYRE
VISOR
HS (or IIS?)
DRY
DISP
BIAS
KNRO
INSRT (?)
SCA(obscured)
AERO
DOWN
UP
You can clearly see everything here>
It's SCAR and HS.It's KNRG instead KNRO.I still don't know what is exactly the function of VISOR button.
Fernando Alonso is the best pay-to-drive driver in F1 with the biggest amount of money behind him.
http://f1bias.com/2012/04/05/truth-abou ... nder-2008/
scarbs
scarbs
393
In wet conditions drivers use a heated visor to prevent misting. The "visor" switch turns it on...
Raptor22
Raptor22
26
Hey they even have a Scarbs button; SCAR :lol:
