Lotus E20 VD
Owen.C93
Owen.C93
191
Re: Lotus E20 Renault
The diffuser is naturally very DF/Drag efficient. So the idea of a complex/draggy system being fitted to route 2 small ducts of air to blow over the diffuser and then switch it off with DRS seems a bit of a waste.
The Merc system of stalling a very DF/Drag inefficient front wing and also balancing DF levels during DRS use seems much more beneficial.
N12ck
Huntresa wrote:A reflection that has a clear edge ? :O Also how does a hole make something blacker ? A shadow makes something blacker, the hole you are saying its reflection should show the same color as the endplate, no ?
that is a reflection look below the DRS actuator, and you will see it is a perfect reflection of that, this system is not stalling the rear wing IMO
Budding F1 Engineer
N12ck
Owen.C93 wrote:The diffuser is naturally very DF/Drag efficient. So the idea of a complex/draggy system being fitted to route 2 small ducts of air to blow over the diffuser and then switch it off with DRS seems a bit of a waste.
It is not for drag reduction it is for downforce creation, and to remove the extra drag incurred by that downforce produced when DRS is activated
Budding F1 Engineer
bhall
bhall
244
There's no reason to create that mess if the goal is just to send air to the diffuser. You'd simply route it from the airbox scoops to the beam wing to the endplates to the diffuser. Otherwise, you leave the underside of the main plane alone at all costs, because that's where downforce comes from.
I think they're venting the air through a slot on top of the main plane. That's perfectly legal.
Huntresa
Huntresa
How does a hole reflect and make a hole get a shadow ? are we living in a upside down world?
N12ck
find a slot on the rear wing and I will be surprised, it is not blowing the rear wing :lol: you need 3 ducts for an F duct,
to huntresa: if it is a hole (which its not) it is ilegal, I have checked the regulations and there is no way it can be legal
Budding F1 Engineer
Huntresa
Huntresa
N12ck wrote:find a slot on the rear wing and I will be surprised, it is not blowing the rear wing :lol: you need 3 ducts for an F duct,
I am not saying it is blowing the rear wing, i just want an explanation for the holes in the endplate, that are in the drawing you are quoteing up top, and also if they arent blowing the RW, then what is the strut going to the RW doing ? Since even there the drawing has a hole.
Owen.C93
Owen.C93
191
Here's another angle that proves it is a hole and not a reflection. If we ignore the rest of the system for a second could anyone explain to me how this hole it legal? I thought constant radius rules were in effect or is that only for underneath?
Huntresa
Huntresa
another pic to prove the hole,
bhall
bhall
244
bhallg2k wrote:It looks like there's a slit on top of the main plane, but it's hard to tell. I need a better angle.
(Click to enlarge)
Look at the top of the main plane. And end plates, for that matter.
Huntresa
Huntresa
Thank god for sensible ppl :D
N12ck
the duct from the rear wing is the signal duct (like putting your hand over the F duct ala 2010)
lets say it is a hole, the only way it can be legal is if it is in the vertical plane,
Budding F1 Engineer
bhall
bhall
244
You still wouldn't need a duct that feeds directly to the main plane. That can all be done in the end plates, just like Mercedes.
Huntresa
Huntresa
Its the same as mercs holes, no ? Not in the way they work but the way they are designed.
MarkedOne8
MarkedOne8
N12ck wrote:if it is a hole (which its not) it is ilegal, I have checked the regulations and there is no way it can be legal
Well, Mercedes' holes are consideres as legal ones.Why Lotus' holes would be then ilegal?
I support your theory about blowing diffuser, but you are not right about endplate holes.They are real, they are not reflections.These holes are always exposed to air, but I don't know why.
It's shame they are not going to run this system in race.Grosjean could test it without risk because he has grid penalty.I don't believe he would have that much better Q position than Kimi, so he will probably start behind Kimi.
Fernando Alonso is the best pay-to-drive driver in F1 with the biggest amount of money behind him.
http://f1bias.com/2012/04/05/truth-abou ... nder-2008/
