F1 Quiz Chain
xpensive
xpensive
214
Re: F1 Quiz Chain
Tiago Monteiro, third in the awful 2005 USGP?
CMSMJ1
CMSMJ1
Re: F1 Quiz Chain
Indeed it was X.
Easy for a man of your triva powers.
Your go...
IMPERATOR REX ANGLORUM
xpensive
xpensive
214
Re: F1 Quiz Chain
Naah...more like thinking a portugee on the podium must have been in the oddest of races and it was.
Which Formula one race is generally considered to be the last Grand Prix won by a true privateer?
Websta
Re: F1 Quiz Chain
Was it Jo Siffert when he won the British GP in 1968 for Rob Walker Racing Team?
xpensive
xpensive
214
Re: F1 Quiz Chain
Hmmm...a little too easy to google that one I guess, your go.
Websta
Re: F1 Quiz Chain
My first question, might be a bit easy so I made it two part:
What was the last water cooling system used for driver comfort in a race, and why did the driver not want to use it again?
Websta
Re: F1 Quiz Chain
I think I ruined the quiz chain, but the answer I had in mind was Keke Rosberg's water cooled helmet he used to great effect in the blazingly hot 1984 Dallas GP. It was in fact a "cool cap" he wore under the helmet, but he complained that the added weight strained his neck during the race.
I'm not sure if that is the correct answer though as I fear that Mercedes ran water-cooled vests during the 2010 Singapore GP as Nico Rosberg can be seen wearing one on Brundle's grid walk. But no one ventured an answer so no harm done I suppose.
xpensive
xpensive
214
Re: F1 Quiz Chain
Need to kick-start this thread;
The Lotus 76 had an aerodynamic feature completely against the ideas of the far more successful 78/79, what was that?
And no, I'm not thinking about the original twin-wing in the rear.
marcush.
marcush.
159
Re: F1 Quiz Chain
xpensive wrote:Need to kick-start this thread;
the original 76 had very short sidepods ? or better it was very narrow you could barely see them as sidepods... The 78/79 used all width available to create downforce -they were formed as wing profiles and ended with endplates + skirts to seal to the ground.
I think Lotus knew at that time already about the potential of the sidepods when using a seal -skirt ..but ran something like a skirt -in brushform -only at the end of season race in Fuji in 1976 ...and they won ...ok that was a 77 -B spec- methinks .
strad
117
Re: F1 Quiz Chain
electric clutch ;)
Sir Stirling Moss
xpensive
xpensive
214
Re: F1 Quiz Chain
strad wrote:electric clutch ;)
There was indeed an electrical clutch, but that is hardly an aerodynamic feature.
Lead; take a look at that spoon-shaped nose?
http://www.ultimatecarpage.com/pic/1458 ... rth_1.html
xpensive
xpensive
214
Re: F1 Quiz Chain
If you look closely at that image fellow members of this great forum, there was a slot between the nose's rear end and the tub, connected to a "grill" underneath the nose, where the idea at the time was that it would eliminate "the air-cushion" built up under the nose and sending the imagined "over-pressure" through the inside of said nose and over the chassis.
I can still remember Ronnie reporting seeing glass-fibre blowing out of this slot under breaking, confirming that it worked.
Only a few years later, with the arrival of Tony Rudd, they realized that the real idea was to indeed get air under the car.
How I miss those days.
xpensive
xpensive
214
Re: F1 Quiz Chain
Right, let's make things a bit easier, how many pedals did the electric-clutch Lotus 76 have?
scuderiafan
Re: F1 Quiz Chain
xpensive wrote:Right, let's make things a bit easier, how many pedals did the electric-clutch Lotus 76 have?
Four? Gas, brake, clutch...electric clutch?
"You're so angry that you throw your gloves down, and the worst part is; you have to pick them up again." - Steve Matchett
Patiently waiting...
Matt89
Matt89
Re: F1 Quiz Chain
Just two, if i remember correctly. The clutch was operated through the button on the gear stick, isn't it?
"Mi chiedete quale è la differenza tra la F1 eroica e quella attuale. Beh, è come se prima si camminasse in equilibrio su un filo sospeso a strapiombo sul Grand Canyon. Ora quel filo è ben teso in camera da letto, a un palmo dal materasso: l'abilità richiesta per camminarci sopra è la stessa, ma la sfida è cambiata per sempre".
- Stirling Moss -
"Se gommo tiene, io vince gara! Se gommo non tiene, io come bomba dentro montagna."
- Markku Alen -
