Engine Brakes, what are they?
MrCodyWeston
MrCodyWeston
I always hear about how engine brakes are used with braking and KERS harvesting, but how does it come in to play? For example, if there is a KERS failure the driver worries about how the car will respond to braking, with engine brakes being used. I'm thinking about Jenson Button in Abu Dhabi in 2011 for reference. Thanks guys!
"I don't care if the door gaps are straight. When the driver steps on the gas, I want him to --- his pants."~ Enzo Ferrari
piast9
piast9
Re: Engine Brakes, what are they?
I think you mean engine BRAKING. The effect that you experience in a manual gearbox car when you lift the gas pedal leaving the gear engaged. Car slows down mainly because of the resistance of engine pumping air with closed throttle. If car has KERS then there is significant additional resistance because of the MGU working as a generator. As far as I know there are no additional brakes in the F1 engine.
Richard
Richard
Engine braking is the friction from the engine slowing the car. You can feel it most on a road car when changing down a gear, the car will suddenly slow down.
autogyro
autogyro
53
Controlling engine brakeing used to be around half of the skills needed by a top racing driver.
Today it is all masked by aero downforce and results in a struggle to stop the rear tyres wearing out.
j3st3r
j3st3r
I read somewhere that the offthrottle engine braking in a F1 car is the same as standing on the brakes in your normal roadcar.
Cam
45
Here's how the big rigs do it. Also, love the 70's retro video and editing - awesome sauce.
[youtube]http://www.youtube.com/watch?v=kl3NLWrj ... re=related[/youtube]
― Socrates
angusf1t
angusf1t
-5
Engine brakes are a special way of slowing the car down at high speed when the normal wheel brakes aren't able to take full advantage of the high aero downforce. A brake disc is placed on the crankshaft, with a set of calipers and pads etc all inside the engine. It acts directly on the crankshaft, which brakes the rear wheels via the gearbox, diff and so-on.
autogyro
autogyro
53
angusf1t wrote:Engine brakes are a special way of slowing the car down at high speed when the normal wheel brakes aren't able to take full advantage of the high aero downforce. A brake disc is placed on the crankshaft, with a set of calipers and pads etc all inside the engine. It acts directly on the crankshaft, which brakes the rear wheels via the gearbox, diff and so-on.
Non of that makes any sense.
The KERS m/g in F1 does this however when recovering energy.
The problem is it unbalances front to rear wheel brake balance, which has to be reset.
superdread
superdread
16
That's rubbish. There are no brake discs inside the engine of any race, sports or normal car. Engine brake is just a name for the braking effect an engine can produce (open valve during compression strokes close during expanding strokes).
There are systems with brakes between gearbox and differential (for lorries and tanks).
Harv
Harv
Definitely not used in any road/sports car, and I've never heard of a commercial road engine using this.
Most engine brakes (which are a separate system) use cylinder compression to slow by valve trickery, which are only on commercial vehicles.
Lurk
I think mainly because it could be easily replaced by any bigger standard brake system for less cost & better overall efficiency.
BTW i just hope angus response was a joke...
wrcsti
wrcsti
Im pretty sure its the force of compression that causes most of engine braking, not friction
650
the F1 car, on throttle closing, is trying to suck air 350 litres/sec past throttle plates (almost) closed to prevent this
that is even a bigger part of 'engine braking' than friction ? (diesels show far less EB for this reason)
Dragonfly
Dragonfly
My pure empirical experience tells me exactly the opposite about diesels.
Spa 2012
650
in everyday driving surely you find that with the diesel you must lift off the accelerator much earlier, or you have to brake more ?
(with a turbo diesel, a N/A diesel is so slow that it's not a true comparison with a petrol/gasoline car, neither is a bicycle)
I was not speaking of enthusiastic driving, changing gears down like the race driver
does anyone else have a view ?
do trucks etc have the engine air throttled on the over-run power-off to help the brakes ?
